PROBLEM WITH MUCH MORE CHARGER
Hi trying to get through to james at muchmore not having much luck my cellmaster v 2 wont charge says low amps it will discharge but not charge anyone else expierence this? ive try diifrent powersupplys nothing works thanks
make sure that you have the right amount of cells setup to charge, if not it wont work.
DID FACTORY RESET GOT NOTHING ALSO IF THE MAGNET TOUCHES A CONNECTOR IT RESETS ITSELF? ANY TIM YOU TRY TO CHARGE IT SAYS OVER AMPS HAVE LEFT SEVERAL MESSAGES BUT HAVE GOT NO ANSWER ?
WOW JAMES JUST CALLED ME BACK IS SENDING A REPLACEMENT NOW !!! FOR ME THANKS MUCHMORE !!! NOW I KNOW WHY THERE CALLED MUCH MORE THANKS!!!!
