Team Corally RDX Phi
#571
Hello, i have 2 questions
1 - to clean diferencial we need to take out 4 screws but the diferencial is in tension, do we need to loose anything more?
2 - My pack goes to tie to the chassi, have you people made anything to the chassi, teh cells are touching the upperdck and the block.
2 - I ground down the little silver nub on the bottom rear of the top deck and also rounded off the edges on the battery slots so they sit just a touch lower. Also you can't have any shrink wrap on the cells as it is a pretty close fit. The idea is to get your cells to just slide right in with no pressure on the bulkhead or topdeck If your cells are bent and banged up you may have to rebuild them to get them flat again
#574
1- I loosen the center pulley too so there's less stress on the belt when pulling the rear diff out
#575
#577
Thanks guy´s, i think we should have a topic where we writh down what we have done to the car, because like the situation of the bateries touching the upperdeck and block causes a lot of tweak in the car and it became really dificult to drive the car. My first race with the car was not the best because the car had stearing for right side corners and don´t have stearing for left side, so i think if we leave a topic in Team and Company discussion (Corally PHI), so we right down the smalles ajustements we do to the car, so we can get better, thanks people.
#578
some one can fit some lipo battery on PHI?
i find only 4000Mah 11,1v stay under the top deck! i have many orion lipo4800 and i would like to use it on this car!
thanks
thanks
#583
make sure your tires are glued properly and check your rear toe. If the changes you made dont get the car to where you need it, then try increasing rear toe in a bit...if its at 2 deg, try 2.5, then 3...you also need to check your rear oil weight and springs. Try first using a bit softer rear springs. THen you can also check your swaybars- try a stiffer front swaybar...
