Xray T2'007
#1066
Originally Posted by Fred Hubbard
Very well!!!. You know I run Mod on indoor high bite asphalt and this car has more steering than the previous car. We are all going to the run on the rug this Sunday, I just got a 10.5 so I MIGHT run rubber tire since it's going to be a pretty stout class and to get ready for that January race at your track but I also just finished up my Gen X last night so I want to dial that in as well. Did Ruben say if Mod is also going to be rubber tire or foam like in years past? But the EU'007 is the ticket. I've been telling peeps down here that I really don't know what else Mr. Hudy can do to produce a more competitive car! But I know they will figure something out
#1071
Originally Posted by protc3
hey guys,
just wanted to post a pic of the new 007 chassis kit that i am going into production with.it is a 3mm chassis and front and rear top decks.i pocketed the chassis down to 2.5mm and added extra pocketing under the arms so you can have more roll center adjustment and droop adjustment.all of the edges of the chassis are beveled and the battery slots are also beveled eliminating all hand work.the kit is alot more rigid than the stock chassis.hope you like it.
#1072
servo saver. top deck posts. layshaft mounts. top deck and rear deck
#1073
Originally Posted by rmargiotta
Rule #1: I'm number 1!
that movie is classic.i cant remember how many times i watched it i think i will throw it in the dvd player tonight.
#1075
Originally Posted by pballkid21587
Has anyone been running double pink foams all around on their 007 for stock racing? I have been reading alot about people doing it but what does it acomplish?
#1077
Originally Posted by bradske
Question about servo placement on the T2 007. Are most of you running the servo mounted in the forward holes? I am using a KO 2365 ICS.
i had to use spacers between the servo mount and servo itself, if not the linkage would rub on the top deck
#1078
#1079
#1080
Originally Posted by duckman996
At Cleveland - some of the top guys were running this combo and found in the early stages they gained 2/10th's versus the typical Dbl Pink Rear/Dbl Pink-Orange fronts. As the race continued on, some of these guys switched back to the traditional combonation as the dbl-pink/dbl-pink combo was unpredictable at times.
