Xray T2'007
#2416
Originally Posted by gunlocators
It seems to not be turning egnough if you put my son tc4 on same transmitter same settings and my xray and just turn a sharp circl his turns much more tighter. Mine darn near needs the entire with of the straight away to make a turn where his takes about 1/3 of it. I do not understand why it would not have a tighter turn radius. I think this is whats killing me in the corners that are tighter cause even if I am going really slow in the turns it seems I do not have egnough steering. I am talking just practicing running the course less than half throttle it seem It cannot make sharp turns. Now if i go really fast in a sharp turn I can slide the back end and clear the turn but doing that everytime is a bit difficult for my drive style
#2417
Originally Posted by B18C Turbo
Well, I mean its hard to believe that all the electrics will make the car slam 1.5mm, let alone slam it to bottom out as you claim. Are you positive this will happen? I have loaded the chassis with some weight to give the effect but no luck!
Update: i added a servo, motor and Rx to the chassis still need a Li-po pack and ESC. Without the battery&ESC I measure 5mm ride height in the rear and that is as LOW as it gets. Im stuck.
get all the bits you still need and check that you've used the correct shock ends from the kit if remember correctly they come with more the 1 kind. Hope this helps
nearly forgot there's also 20g of wieght to bring it up to 1500g
#2422
Originally Posted by Big B
https://www.ssl-stormerhobbies.com/c...s&pn=XRA303411
are these what you are looking for?
#2423
i dont know if im using the right shock ends on this car! What is your total free length of the shock, mine is 65mm!
The longer ends included are for the FK05.
#2424
#2425
Originally Posted by Nexus Racing
I'm not sure about the shock length right now, but you should be running the short shock ends #308316.
#2427
i think you'll find it's been out for a while now and all the early q's have been answered and people are out enjoying them now!!
#2428
"back the droop screws out to get tons of droop (don't want droop screws messing with the ride height setting).
set ride height. push car down to surface, let go, measure under back end of chassis and under side of chassis just behind front arms. Use shock collars to set ride height. left and right shock collars should be very close. If one side of chassis is lower than other, you can make small side-to-side collar adjustment to level it.
set rear droop. lift rear of car by shock tower until one wheel just lifts from the surface. Measure the chassis' height at rear end. Difference between this height and ride height is droop. Turn in droop screws to lessen droop. Keep adjusting screws until both tires pick up exactly at the right chassis height (in this case, 5.5mm).
set front droop. same procedure. lift on front shock tower, watch or feel for one tire lifting off surface, then measure chassis height (just behind front arms). Again, adjust screws so both tires lift at 5.5mm."
This is a way I adjust the cars tweak by lifting the front and rear and seeing if both tires lift up at the same time, though I adjust with the spring collar, should it be done this way or with downstop screws?
