problems with my cars
I've post this one also in the MR4TC SD thread but maybe someone else has the right answer:
I have problems with my car Yokomo SD LCG: I run standard shocks with white springs and blue front. One way drive with Atomic outdrives front and diff with Excell outdrives on the rear (ceramic balls). Pistons are the standard. Problem is that my car is sliding and not controlable. Ride height is 5mm f&R. In every corner it spins. What can I do this to solve this. I run RP tires alaround on asphalt. Please help. |
Check the rear toe
check droop and for binding and then for a bad one was bearing or maybe a broken drive pin?/
check all equip of your car FIRST! Is it free . Bearing / steering / shaft ETC. the Set-up comes second. My car 415msx had the same problem.I change set-up for 2 month but nothing better.I founded that the problem IS one-way . It can't free the same.Now my car is stable and easy to controll. :lol:
HI,
I had promblems with my t2, check for your rear diff being too tight and and pushing the back end out. another thing is, on the wishbones on the rear move the bottom of the shocks the the inside thus giving a more stable rear end the control round the corners! Hope this helps |
Thanks guys for the solutions, I am gonna try it.
also try putting more roll in your radio . this will help with the rear end comming around when you hit the brakes . if you use them . dial out some break too .. then adjust your when and where you get on the throttle in the corners ... have fun and hope this helps ..
markb. |
