Team Losi JRXS Type-R
#4936
I have always run long front arm, and just about always long rear as well, it just helps the car be more consistent and grip better if you ask me....i have run short rear arm on occasion to get it to rotate differently, but it seemed to always be faster with long arm.
#4937
#4938
#4939
I had a discussion with a R&D person from another company who acquired a Type R and dissected it and the way I understand it is this. The arms for the type R are too short for asphalt by 1/4 inch either side 1/2inch total this is the length of the arm not including the hub and hex. In fact getting wider hexes doesnt solve the overall situation because there is something to do with the dynamic forces acting upon the distance between the arm perpendicular to the shock tower............ burn out for my brain right there.....Generally speaking the longer the arm the better the traction in med-low grip situations and the narrow the arms the better for high traction situations hence the Losi on carpet is a gem. Making the arms shrter will apparently provide yet more traction on carpet but as with anything there is a point of critical mass whereby too much of anything can be a bad thing.
I am not a designer nor mechanical engineer and I didnt understand, to some extent, all of the physics involved and why this is so, however the person providing the information is and is also a factory driver and therefore I will take his word at face value. If Ron, Todd or Chadwick or anyone else for that matter want to jump in and fill the rest of us in please do so.
With the JRXS we were struggling with grip on low to medium surfaces. That is why we developed the Type R, motor in the back of the car. The gyrotational effects of the motor in the rear increased grip amazingly.
#4940
As a mechanical design engineer myself, I can tell you that no amount of analysis, or computer simulation will ever duplicate the real-world dynamics that act on anything you design.
It will get you close, but there always conditions that cannot be accounted for. It's why civil engineers design bridges to be a whole lot stronger than what they need to be....a safety factor. It's why these teams do so much testing. Most of what happens in real-life flies in the face of what's expected.
I can tell you here where I work, we have brilliant PhDs that come up with all kids of models and calculations. However, when we do real-world testing, the numbers are ALWAYS different.
So because an engineer can't get an arm design to work on his car layout, doesn't mean it won't work on another. Since the Losi is so radically different than the others, you almost have to throw all previous conventions out the window.
The fact is, the car works...no matter what anyone tells you with regards to the arm length. And it works on the asphalt too....I saw 2 Losi cars make everyone look silly at a big asphalt race last month. To me, that was more important than seeing what the Hired Factory Guns do with it...since they could drive a shoebox with wheels and look good.
#4941
#4942
Unfortunately, I won't be able to make it. It's quite a haul from this side of the state, and I've done all my travelling for the summer. It's pretty much Vegas prep and the occasional nitro race for now.
#4943
I am running Hodges 06 nat's setup and was curious about a couple of things....he has the front hex at .225 and the rear at stock...if I take the rear out with the .195...wil that make it a little more stable through the turns? Also, with reguard to Caster what affect does increasing the angle have (go from 4 to 6)? and conversly from 6 to 4?
#4944
Caster is relevent to the speed you enter and exit a corner where more caster will bring your steering back to zero quicker less caster will decrease grip and make your car rotate on high bite surfaces.
So ideally if you are running a wide wheel base you could possibly get away with less caster (4 deg.) depending on surface conditions.
Peace,
C
#4945
And yes, there is nothing wrong with the car. Everyone can be a skeptic due to the car being completely different than everything else out there. Believe me, I was a skeptic too. I usually base a car on how well it does on asphalt. If you get it to work good on asphalt, where setup is the hardest, it will work on any surface. Larry and I have been working really well together with setups and results show. The Bowl will be no exception. The progress we made last week was awesome considering the uniqueness of the track. I'm definitely looking forward to carpet now too. The stuff we have learned in the past few months is going to help infinitely on carpet.
Anyone that has a Losi car and needs a hand with setup, just stop by and visit us. We're more than happy to help people.
#4946
What effect does legnth of the a-arm have on a car. Ignore shock positioning, and its effect on shock forces as this can be the same. But what really are the effects of the overall length of the a-arm and why is there a difference between a longer arm or shorter arm and hex which equates to the same legnth of the a-arm. Not sure if Im asking the question right. but the question is not who has the best car and what is right or wrong its more of a theoretically speaking why is this the case?
For those of you like myself with small children look at me as the one saying "WHY?" everytime someone says you should do this........ I like to understand the principles behind things not just that it works or doesnt work but WHY does it work? Maybe I should change careers
#4947
In its simplest form, the suspension on our cars act like a 4-bar linkage. 3 rigid bars (arm, hub, camber link) and the fixed bar (chassis).
By changing the length or mounting location of any of the 3 rigid bars, you change the dynamic of how they work in relation to each other.
Even though you might have the same overall "length" of a-arm, there's still a change in geometry since you moved the pivot points as well.
http://en.wikipedia.org/wiki/Four_bar_linkage
There are all kinds of 4-bar linkage simulators out there, where you can change the links around and see the effects on velocity, angular acceleration, etc.
#4948
True True
True True
#4949
I owe you a beer thanks man see you in the fall.
#4950
Andy
