Team Losi JRXS Type-R
#3541
Originally Posted by Keith Billanti
I use the AE fans as they have black wires and are pre wired together... they look sweet.
KB
KB
#3542
Originally Posted by Yeti35
How are you guys getting power for your fans, just pluggin them into the receiver or direct soldering to some other power source? My shop has the AE fans attached with one plug that would go into the receiver. I was thinking about getting those.
Malc TCCFM
#3543
KB
KB
Malc The only kidding you Man
#3544
So AE stuff does work in a Losi? Oh, and another question, WHERE IS OUR ONE WAY?!!
#3545
I soldered my leads to the pos(+) and neg(-) of the speed-control.... with a separate switch to the fans - that-way, I could keep the fans running after I switched-off the car when I went to go marshall. When I get back to my pit, I have a nice and cold motor.
Martin
#3546
Originally Posted by TheCoolCanFanMan
The prob is, with the fans mounts situated on the bulkheads, is that the fans do not sit directly over the kan, and blow partially on the bulkheads so therefore not getting the full affect of the fans cooling the kan,brushes and arm, this is why I felt it was better to move them over a tad
You can purchase fans from most electrical shops but be aware as most of them will slow down or even stall over a motor kan that has strong magnets due to thae fact that the internal make up has a steel ball bearing inside, the fans on a CCF are of a different make up entirely, and will not stall over a kan with strong magets, you pays your monies and makes your choice.
Cheers Malc
Cheers Malc
Thanks for the help so far.
#3547
Originally Posted by duckman996
Yeti,
Martin
Martin
I did the same. I did also add a connector with all three fans wired together. This way I can unbolt and unplug the fans if I need to in a pinch.
Brant
#3548
KB
KB
#3549
I can only get one fan on top of my BL motor due to the location of the wire tabs. I've been alternating between a clip-on heatsink and a fan to see which provides better cooling. Seems like the fan is the winner.
My backordered EA3 6 degree hubs arrived today, so I guess that means they're available now. I don't think I'll bother switching out the graphite unless they break.
#3550
Ed,
Where are you racing this weekend.
Chris
Chris
#3552
Originally Posted by Spillertwo
Do you perhaps know the part number of the AE fans ?
https://www.ssl-stormerhobbies.com/c...=ns&pn=NOV5647
or two pack
https://www.ssl-stormerhobbies.com/c...=ns&pn=NOV5651
Brant
#3553
Originally Posted by Dasupacat1
I just switch my M8 off. Leave the car on. With the Spektrum everything goes to neutral when it loses the trans signal. T
E
#3555
Ed,
Will be at Aldershot for BTCC, practice for 27T National
in May, working on set ups.
Chris
Chris
