Corally SP12X
#241
how do you setup the T bar tweak screws? Do you turn them down untill they touch the chassis and then adjust for tweak or do you keep some kind of clearance (1mm like the manual says)?
On carpet you put them on the chassis. Not sure why the manual shows clearance, except maybe for low traction asphalt.
Korey's setup a few posts ago would be one good one to try. Jeff's Cleveland setup was a little different, and also good:
Jaco double pink frt 1.65" (1/3 sauce), yellow rears 1.75" (full sauce)
1.6mm T-bar with side to side stiffeners (hard rubber spacers under each side of T-bar), 2 screws mounting to rear pod with spacers cut as Korey says
30 wt shock oil, silver spring
around 1mm uptravel at rear of main chassis (lift at rear shock mount to check this- change shock length to adjust)
chassis level when race ready
Corally red lube in dampeners
.020 frt springs, Corally diff lube on kingpin
10 degree blocks, 2 spacers rear and one front
1.25 degrees camber
3.5mm ride height
#242
Where are the side to side stiffeners put? under the top of the T?
#243
Halfway under the t-bar. It is a rubber o-ring we used on both sides to stiffen the t-bar up. We didn't want to go all the way to the 2.0mm t-bar so we came up with that idea. You can shift it back and forth to change the feel to fine tune it.
Jeff
Jeff
#244
Yea, I just tried that today and really liked it. If you use a rubber type oring... rather than a silicone base then it seems to do a better job. The rubber ones are harder. I used some head dampener orings I use on my r/c heli since they are pretty hard. But any rubber type of oring will work I think. I just put a little drop of ca down on them to keep them still.
-Korey
-Korey
#245
What type of camber gauge are you using to fine tune 1.25 degrees of camber?
Nilezb-
1.25 degrees camber
3.5mm ride height
1.25 degrees camber
3.5mm ride height
#246
#247
So are the o-rings b/w the pivot balls under the t-plate? Doesn't this increase the 'spring rate' of the t-plate as well?
#248
This way you can adjust side-to-side stiffness and separately tune front-to-rear stiffness with the shock spring. Sometimes the jump to the 2mm T-bar can be too much.
#249
Thanks, I'll have to try this next time out.
#250
A question came up from a racer about the proper countersink for the 12x chassis screw holes. The countersinks on some of the graphite parts in the kit may not be quite deep enough to allow the screws to fully seat flush with the surface of the graphite. This can be a problem, of course, when running low ride heights on carpet.
The Corally metric screws have a 90 degree countersink angle, unlike the U.S. standard 82 degree countersink. To maintain proper retention and alignment be sure to use the 90 degree version.
These can be found on www.mcmaster.com, Catalog Page 2421, for $6-$8 depending on size.
#251
Hey Larry,
do you do the same for corally tc's and use a countersink to make sure they are flush?
#252
#254
Question:
I finally dusted off the box and decided to run my 12X. I have an issue with the wheel hubs not aligning with my JACO PRISMS. I have ordered new wheel hubs due to the ones I have being somewhat stripped.
Is there some ritual to follow when mounting the rear tires???
Diff side tire is ok... other side... wobbly...
Here are some pics of the completed car:
#255
Question:
