US Indoor Champs 2006
#931
It's cold about 34 rigth now forcast next week is rain maybe some light snow temp around 50
#932
Are we there yet??
#935
4 days or 96 hours till the world comes to Cleveland
give me till about noon
#936
Not a problem. About noon is like 11:00.... right?!?!
Just giving you grief. Take your time.
#938
The heat board is now posted under the 06 results box.Please keep in mind it is subject to change!
#939
Damn I am in dialed qualifiers and I am not coming
See you guys next time.
#942
Does this help?
Maximum length - 460 mm
Maximum width - With body - 195 mm
Height - Minimum - 130 mm
Minimum ground clearance for carpet racing is 4.5 mm.
Wheel base - Minimum - 250 mm
Maximum - 270 mm
Minimum weight - 50 ounces
Wheel diameter - Minimum - 47 mm
Maximum - 50 mm
Wheel width - Minimum - 24 mm
Maximum - 26 mm
Tire diameter - Minimum - 55 mm
Maximum - 67 mm
Tire width - Minimum - 24 mm
Maximum - mm
Batteries - 6 cells maximum
ROAR Approved Bodies only
Maximum - 270 mm
Maximum - 50 mm
Maximum - 26 mm
Maximum - 67 mm
Maximum - mm
#943
Originally Posted by John Warner
Does this help?
Maximum - 270 mm
Maximum - 50 mm
Maximum - 26 mm
Maximum - 67 mm
Maximum - mm
Maximum - 270 mm
Maximum - 50 mm
Maximum - 26 mm
Maximum - 67 mm
Maximum - mm
#945
3 days or 72 hours till the world comes to Cleveland
wheel width is 31mm, the hand book was already in print before the rule change
