3racing Cero Ultra V1 & V2
#902
Can anyone explain the Final Gear Ratio chart in my Cero Sport 55 Manual. I think I got my final gear ratio and final drive ratio confused. I ordered a bunch of spur gears ranging from 72t up to 76t to go with a 18t pinion. This was I thought to achieve a 7.6 final drive ratio (and above) for modified touring (4.5t motor) but I now realise the chart shows final gear ratio, so i think I’ve ordered the wrong spurs and pinion.
The other issue is the gear ratio states for a 72t spur and 18t pinion doesn’t match when I do the calculation. It’s saying 7.6 in the book but 4 when I divide the spur by the pinion.
#903
FDR = Spur * 1.90 (drive train gear ratio) / pinion
72*1.90/18 = 7.6
Its just their print/wording
#904
Mick, don't be fooled by Marcos pic, that is not a stock Sport 55, you will need at least metal hubs on all four corners, and the ball studs on the diff covers pull out easy, might want to get longer ones. Read the past posts on issues with the sport.
#906
SAK-C141 (racevta.com)
#907
I had a bit of a tumble a few weeks ago and the screw the screw and bearing popped out of my steering bridge. I reassembled and it appeared to be fine but as a back up I went to order a replacement and noticed that the V2 has an updated steering bridge and appears they switched to a larger bearing on the bridge?
#908
yep. I put that on my Ultra. Works nice.
#909
Any word on the release date of the aluminum chassis for the ultra 2.0
#910
#912
#913
#915
I am using: XRAY 1.5mm Bearing Supported Rear Anti-Roll Bar [XRA303805] for the T4
