Team Associated TC5
#1366
Originally Posted by Rick Hohwart
Peak Dynasty 19T
#1367
Wow, that's so unbalanced. Keeping up with the legacy of TC4 with the motor-side extra weight.. Or is there a secret lightweight BL motor coming out?
#1368
The motor sits in the position it is in for the purpose of perfect weight distribution. This particular top deck is for maximum stiffness for foam tire carpet racing. The one in the other photo allows for more flex on rubber tire carpet or asphalt racing.
In this photo, the car is set-up with a heavy body and only required 3/4 oz. to bring it to the minimum. With a standard lightweight body an additional 1/2 oz was required. Full production parts will lighten things a bit more as will the use if titanium hardware.
#1370
#1372
Looks good to me... how long before I can get one?
#1375
DUDE,
sign me up for one. I ready to go
Later
Kevin Boyle
Later
Kevin Boyle
#1376
Originally Posted by RCSteve93
The farther the motor is out, the heavier it gets on one side. It is like balencing a tweak station, or using a balance scale. I am really bad at explaining things. Can someone help me out if you know what I am talking about?
#1377
White outdrives are probably made out of delrin, most likely for prototype purposes
#1380
O ! Look !
C-main R/c tech designer`s.....
available for cheap....
