Team Associated TC5
I did some setup changes today, and I realized how important rear diff tightness is just by loosening the rear diff and changing to a thicker sway bar I was able to push the car so much harder now without having the rear end step out. But I still need to somehow gain at least .5 seconds per lap.
whats the easiest way to see if the chassis is tweeked. If it is whats the easiest way to fix. THe problem im having is on power it want to pull to the left on the straight
I really want to put my 1 way back in, but there is a big race coming up and they won't allow 1 ways!
I do have a ball diff. I'll see if I can get it together. I tried black sway bars, but it made my car feel like it was on ice. I don't know why they wont work for me. Everyone else seems to like them.
Today, I'm going to try 40 wt oil and 6degree caster blocks. I'll report back later today.
Do one thing at a time. Change the front shock wt first.
Not too sure how to see tweek, one method I've told to remove is to loosen of the chassis plate screws and just let the carbon fibre to re-settle it self for a day or so and then re-tighten the screws.
The easiest way is to lay your car (without wheels) on an ultra flat surface such as a setup board or perhaps, a glass table top. Look at the chassis at eye level and if it doesn't sit perfectly flat on the table top, then it is tweeked.
The easiest fix is to loosen the screws on your top deck and then press down on each end of your car as your re-tighten your screws. If that doesn't fix the tweek, then loosen all the screws for your top deck, bulkheads, bearing caps, shock towers and then carfully re-tighten then evening. If that still doesn't fix the tweek, then you may have a tweeked chassis or even a bent bulkhead. Also, pay attention to your battery and how you tape and/or screw the battery mount on as it can tweek your chassis, too.
TC5
I'm not a newbie, but I have a question that makes me feel like one. Reading this thread I see to build the shocks with no or very little rebound. I've tried everything to get there, but I still get alot of rebound. What I'm I doing wrong?
Jim
Jim
Tweaking
Using a tweak station is a good way to get your wheels on the same plane. A good practice is to set the front wheels level with the chassis first. Shorten the tweak station and set the chassis on the stationary tweak bar, just in front of the rear wheels to do this. Then set the tweak bars to the wheelbase and set the front wheels on the stationary bar and adjust the rears. This way the tires and chassis will both be on the same plane.
My tc5 has a solid diff,is that what comes with a new kit?Whats the correct length to build the shocks?
Thanks Bfong. I'll give that a try. What size hole should I drill in the cap?
Actually, I just used a body reamer to make the bleeder holes. The bleeder hole should be really small, just enough so that any air can evacuate from the cap. If you notice towards the bottom of the post I mentioned, I posted a picture of the actual bleeder hole in the shock cap. Hope this helps.
Thanks again bfong. I used a 1/16 bit, and it seams to work fine. At least I have no rebound. I won't race again until next Sunday, so I'll try this setup then.
Jim
Jim
That's where I ended up for the day.
My best weekend by far with this car. The car is very drivable, predictable, and stable. I would have played with more adjustments, but there is only so much time in a day.
I could always use more on power high speed steering if it is possible. I know there is only so much possible. If you have anymore suggestions to try, I'm all ears.
--pakk
--pakk
Also, have you tried running sway bars since you changed to this new setup?
I see what you're trying to do by moving the front shocks to 4b...you're trying to get the front end to react.
At this point, I'd probably recommend trying sway bars again. Also, perhaps even going thicker with your front oil, perhaps 50 or 60wt. Prior to changing from a slipper spool to a 1-way, I ran 60wt and a silver sway bar in the front and 40wt with a black sway bar in the rear. It ran alright, but also needed more on-power steering. It didn't really get good Tamiya/X-Ray smack down steering until I switched to the 6deg caster and the 1-way.
Are you running RCGT and that's why you can't run the 1-way?
Does anyone know where i can get a set of inline rear bulkheads?Just recently switched from losi back to the 5.
