Team Associated TC5
#76
Sooooo, I'm not getting beat cause my batts don't have sky high numbers?!
#77
the spur would run in the same direction even if the motor was moved to the other side of the chassis
#78
#80
As far as shaft cars go...
Originally Posted by TadehI
They should have used the Pro 4 diff houses. Theres no binding out of the package. They are perfect.
#81
So,
I guess this car was not at the worlds warm up race. So I guess time will tell if AE brings the car to life and if shows up at the worlds?????
Later
Kevin Boyle
Later
Kevin Boyle
#82
Originally Posted by JWATT
If the pinion is moved to the other side of the spur, it will reverse the spur's direction is the point I was trying to make. By moving the motor from one side of the car to another, it will therefore be on the opposite side of the spur.
On a belt the motor will spin backwards. Unless as Jon Kerr said you can put the motor in front or behind the spur gear but not switch sides.
#83
Originally Posted by speedxl
The motor can be switched from side to side without a problem on a drive shaft car. Motor still spins in the same direction!
#84
Yes, you are right the motor spins the same direction, but by being on the other side of the spur, the SPUR'S direction is reversed.
Only one thing changes when you move the motor from one side of the drive shaft to the other...the relation in which the drive shaft and the motor amrature spin in relation to each other. On a stock TC3/4, the drive shaft and motor armature spin in toward each other. If you put the motor on the other side of the car, now the drvie shaft and the motor armature spin away from each other
#85
Originally Posted by koabich
Well just rememebr that RC cars are not for everyone! Just because you want to be good at it doesn't mean you will be.
I want to be awesome playing guitar but after 10 years I still stink. I wonder if I can blame it on the guitar??
It's not how many years... but how many hours....and yea your guitar could suck.....
#86
#87
If the motor spins in the same direction, how can the direction of the spur be reversed? If the spur's direction was reversed, the car would run in reverse as well. The spur is not reversed.
#88
So not too many hours then hu, bucket boy??
#89
Just haven some fun buddy .....
