Serpent X20
#391
Yes that was pretty much the key to get the car running great. I was looking at the Y brace kit for the rear tower. I have not stiffen up the rear yet with the rear post yet. I sure could see it useful at Beachline once the traction comes up.
Can the Y brace be used for front and rear or are the 2 Y braces different?
The front and rear Y braces are the same, not sure about the aluminum mounts though..........have to check.
#392
I think Dawgmeat means he used the Y brace on top of the top deck where the 4 screws are located, as the spacing for the Y brace is the same as the top deck. I use the Y brace at the front of the deck just to give it a little more strength when I run the stock top deck.
#393
Super Moderator
I have a RSD 1.5 and 2.0mm top deck. I Think it is very firm and don't think I will need the Y brace for that area. I have been reading about the Y brace on the rear shock tower. I am not quite sure how that brace helps in a vertical position. I have been just trying to find out the theory behind it and what it benefits.
#394
After reading on both X20 forums I feel that I have the flex under control and can focus on the fine tune to get to your speed.
#398
#399
Also I mounted the cap on the other side beside the battery. That is the standard way. I kind of made a mode to clean it up a bit more. Everything including the cap goes into the box. No worries of extra wires or even if you need to add weight. You can put the weights on the bottom inside the box.
#401
In fact I really like this tuning option now. I can add or take away flex in different areas to find the extra speed. The car is VERY fast and has a very good forgiving feel. Plus the parts are very durable.
The only issue is with all mid motors. The front belt will come off track if you have a direct hit. Perhaps the middle post will help with that TBD.
I hope this helps someone.
#402
Hello from Greece! I just bought a x20 mostly bcs i want to make a new project and the pivotball solution is smth different to other kits. I race only xray cars. I have two questions: Is it normal that my front driveshafts came already prebuild?? And secondly and most important: although at front of the chassis there is the small hole for balancing tool, at the back there is nothing. How do you balance (L-R) your car? Is there a balancing tool specific for the car or a similar solution??
#403
1 - DJC come pre-assembled but you should take them apart and lubricate them. Also make sure you have the c-clips hooks rotating the correct direction for each side of the car. The hook should lead into the rotation. I also put a very small dab of glue on the c-clip so they don't fall off.
2 - For the back hole just put a 3mm flathead screw and nut in that open hole, then balance as normal.
#404
Welcome to the crew.
1. Acrylic glue or smth more "soft"?? In parts where I don't want "permanent" bond I use "shoe goo"(hudy) or nail polish (especially in plastic parts). Do the front driveshafts from the FWD car fit ours??
2. I was thinking of doing that, bcs I will put the rear stiffener mount, so there will be a m3 screw.
#405
Thank you for the info.
2. - that will work as well.
If you do disassemble the DJC take note that there are 2 different sized spring clips, don't mix them up or one will be a little loose and the other will not cover the cross pin completely.
