Team Associated TC7.2 Factory Team >
Like Tree261Likes
Old 04-02-2019, 07:16 AM
  #361
Originally Posted by Rgee480
What is everyone using for a fan mount?
I just use the Xray t4 fan mount
Megatron328 is offline
Old 04-02-2019, 11:47 AM
  #362
Just double sided tape, it also helps smoothing fan vibrations (I know it doesn't impact performance but i hate having a car that feels like a wasp nest)
Fastfreddy74 is offline
Old 04-02-2019, 12:16 PM
  #363
JC3
JC3's Avatar
Tape is all I've ever used. Never had a problem.
JC3 is offline
Old 04-02-2019, 12:46 PM
  #364
Thanks for the suggestions.ni appreciate it
Rgee480 is offline
Old 04-02-2019, 12:47 PM
  #365
Originally Posted by MattW
Hasselhoff, yes, in the UK we've been shimming the mount up and only using front screws and like you, have found a big improvement on our medium grip tracks.
i was really impressed, puts it on par with the mugens and infinitys on the track. Before i was only just keeping up because i couldnt push it very hard on corners. What diff oil do you use for medium grip ashpalt over there?
Hasselhoff is offline
Old 04-02-2019, 01:57 PM
  #366
Thanks for the input guys
Rgee480 is offline
Old 04-04-2019, 06:28 AM
  #367
Bar
Has anyone tried running the extra top deck screw in by the spur for asphalt?
Bar is offline
Old 04-06-2019, 08:30 AM
  #368
Hi Matt, could you passed us your outdoor setup? Sweep tires right?
jorgesimes is offline
Old 04-08-2019, 01:41 PM
  #369
It's up on the Team Associated - CML Touring car team page on FB.
jorgesimes and jmarinheiro like this.
MattW is offline
Old 04-08-2019, 02:46 PM
  #370
seen it, thanks, will give it a try.
Old 04-08-2019, 08:15 PM
  #371
CristianTabush's Avatar
Default New RSD Items
Hi Guys, wanted to post some of the items we have been working on for your TC7.2:
Hard Wide Front Bumper Kit for TC7.2
Camber Mount Shims for TC7.2
Camber Link shims installed
PCS Braces in 2.0 and 3.0mm
Spec Racing Top Deck
Extra clearance for larger pinions
Inset front battery hook
Inset battery hook moves the battery inwards at the front for much better balance with larger packs.
CristianTabush is offline
Old 04-12-2019, 06:49 PM
  #372
Does anyone know if the Blue TC7 / TC7.1 Bulkheads are compatible with the TC7.2? Is it just a color difference, or are they mechanically different?
Awesome parts btw, Christian
CristianTabush likes this.
AndyArdmore is offline
Old 04-12-2019, 11:50 PM
  #373
yes Andy it’s the same design but black bulkheads are made by harder HD choice,like black option parts of F6.
AndyArdmore likes this.
Andrea Efficace is offline
Old 04-13-2019, 11:26 PM
  #374
Default One more new item
TC7.2 7075 T6 Aluminum Flex Chassis
*Prototype shown, production has no CS for the outside holes on the battery hooks.
We are very proud of this one. Lots of testing by our team drivers to get this chassis just right. It was developed to be used in hot weather or high bite asphalt, and medium to medium-high grip carpet.
100% performance oriented, 100% made in the USA!
Poor_Boy and aracefan like this.
Old 05-24-2019, 11:43 AM
  #375
proliteandsc's Avatar
What servo do you guys recommend, or specks should I be looking for?
proliteandsc is offline
