Tamiya shock
Tamiya shock
Hey guys can you help me out real quick.
I am looking for the latest and greatest Tamiya TRF shock.
some of the oval heads are running it as a center shock and wanted to try it.
I thought it was part number 49293 but looks like that one was discontined.
EH
EH
I guess a follow up question would be, is there a better shock out there than the tamiya ?
X-ray, Kyosho, Losi, HPI (i currently use the 72170) on my pan car.
Is it BETTER than a Tamiya-I dont know, but its even easier to rebuild and make piston changes.
you know us oval heads Ray, we could care less how long it takes to build...
we need the smooothest !!!
It used to be HPI and
am I am hearing the Tamiya is top dawg right now.
I am gonna need part numbers if you recommend a shock to run
They are absolutely right, the TRF Shocks are top of the line!!
As you only need 1pcs, this should be perfect for yor application!
Part# 53901
Add these oil dampers to your F103GT Chassis for even better performance. Low friction fluorine coating of cylinder, together with titanium coated piston, secures smooth damper movement. Adjustable type spring retainer allows for fine tuning of spring pressure.
Part# 53901
ok
I am thoroughly confused
what is the diff between Tamiya part numbers ?
53571. 53901, 49293 and 49355 ?
and can somebody give me the losi part number ?
53571 = 4pcs complete Flourine coated shocks, grey, standard color.
49355 = 4pcs complete Flourine coated shocks, blue color w/alu spring adjuster.
53901 = 1pcs complete Flourine coated shock, blue w/titanium shaft and alu spring adjuster.
49293 = 4pcs complete Flourine coated shocks, blue color, w/Mounting hardware
