Tire Gluing Question
Short and sweet...
When you glue your tires, do you apply the glue to the tire or the wheel when you're going around the bead?
First I wipe the tire bead and wheel with some motor cleaner or something to remove any residue. Then I'll dry fit my tire and insert (if applicable) on the wheel and I make sure its even and well seated. I will then pull the bead out in small sections, glue the tire bead lightly and reseat that section working my way around the tire. Some glues set faster than others, if you're not sure on how fast it will set, do a small section, reseat it, then move to an area farther away from what you just did, allowing the section you just did time to cure. Just keep alternating spots until you get it all glued all the way around
the wheel trough,, and then finally the tire and wheel edge seam..
If so... that's one for the plastic, one for the rubber so far. Please let me know if I misunderstand what you actually do.
both the tire and the wheel at same time. You have about 2 seconds to get the tire on the wheel right once glue is applied. Put the insert in tire then put on wheel, the glue the 2 together. many of you tube videos on how to do it. Look for adam drakes, ryan lutz, or ty tessman's videos on how to glue tires
R/C Tech Elite Member
I use really stiff tire bands. Clean the crap out of both tire and wheel first, seat, tire bands, pick a spot to start and then run around the head pulling it out as I go and gluing it and reseating as I go. Takes about 10 seconds per tire. Do one side, let cure, move the band to the other side and repeat.
I've watched all the videos - an the main reason why I'm asking this question is because the videos are all shot from so far away that I'm not able to tell exactly where the glue is being applied.
racingnewb brings up a 3rd option - and maybe this is what most of the pros are doing in their vids - when they pull the tire back to expose both the tire and wheel beads, they apply to glue right in the crack between the two and then seat the tire into the wheel. Does that make any sense?
Another reason why I ask this question... I've glued three sets so far... the first two times I would pull back the tire and put the glue directly in the WHEEL BEAD then seat the tire. They turned out like shit. My 3rd attempt, I changed it up and applied the glue directly to the tire while it was pulled back - this gave me the ability to do what Lutz is doing in his vid... making sure the tire is seated properly.
I barely pull the bead back. You want a small gap, such that the CA glue wicks down into it. I find if you pull back far enough to see the wheel, or even the bottom of the bead clearly, then it's easy to put way too much glue. It also pulls the tire more out of shape and it can get stuck that way if the glue cures before you get it fully back into place.
For 1:10 tires, I put them flat on the table, then barely push the sidewall down and slightly away from the wheel. I get just enough to get a thin glue straw in there. Apply glue and it wicks around the bead. Really, I'm trying to glue the outer edge of the bead to the inner face of the wheel. I think that makes a stronger bond. Some will wick around and under the bead, but really gluing the side of the bead to the inside lip of the wheel is what gives more strength.
to clarify the glue should probably touch the wheel first with the tire pulled slightly back, so when the tire goes against the wheel it pushes the glue to the top of the bead making a good seal, then after the entire wheel/tire is glued put a small bead around the tire and let it flow around the entire tire to help fill in any voids, then wipe everything away
https://www.youtube.com/watch?v=PqYXaB9uPoU&sns=em
