Best Stadium Truck for large dirt track?
I'm looking for a seriously tough stadium truck. I'm building myself a 1/8 scale focused track, but at the back of my mind I keep thinking I'd like to run a stadium truck (or similar?) as well. I have taken the time to designed in short jump options, so I think a stadium truck would do alright? But I don't have enough experience to know what kit is most likely to hold up well.
My track: http://www.rctech.net/forum/electric...sign-help.html
Before I get too far, should I be thinking 2wd SCT? I like the idea of the proline pro2 buggy. I could run the buggy body on my track, and swap to an SCT body on race day. The 2wd SCT was by far the biggest class, but I'm not 100% on what the current state of play is at the local track.
I ran a Durango dest210 for a season 2 years ago. I won several races with it, but of course Durango has turned belly up.
I was excited about the Xray xt2, because everyone says their stuff is tough. But then I found out that they don't currently offer a cover for the spur/pinion, which will certainly be a problem on my track.
The Losi 3.0 sounds pretty good? But I really don't have a clue. It'd be awesome if someone can comment on all the readily available ST kits? What has the best chance of holding up on a punishing track like the one I'm building?
And I don't know where to start in picking an appropriate motor. My DEST210 came with a 17.5, and later I got a 13.5. I won several races, beating people with lower turn motors...but I never attempted to run on a big track like what I'm building. Should I be thinking 13.5 because of medium to low traction? Or should I be thinking full-on mod motor because of long straights and big jumps?
Any thoughts about running a 2wd buggy on a dirt track? I expect ground clearance will be an issue...which is why I started thinking truck.
But the thing is there appear to be ~20 different 2wd buggies, but there are only 5 options for truck, -1 b/c it's the old Losi, -1 b/c Xray doesn't have a gear cover...leaves 3 choices! (Based on Amain inventory.) Kind of disappointing, really.
If you have a loose track, I really wouldn't go with the XT2. It's got a laydown and the weight distribution is nearly 50/50 (when I had one it was 52 rear, 48 front with the battery all the way back.) That's just way too much weight on the front for a loose track. Add a $75 ball diff and the XT2 is not practical. In my opinion, the XT2 should be kept on the carpet and high bite clay it was designed for.
Take a look at the Pr Racing ST1 V2. It comes rear motor which might be ideal for you, but it can convert to mid motor with a few parts. It is a very durable truck with two upgrades. The steering blocks to the pro-blocks with the carbon fiber plates, and the 3mm motor plate.
A plus is the V2 truck can be found relatively cheap. $239.99 here https://evohobbies.com/kits-rtr-s/ho...-shipping.html
Losi 22t 2.0 is my recommend to. Rear motor will make a good difference in loose dirt and the 2.0 can be configured as both.
I broke down and bought an Ebay special. It's a Losi 1.0, but super clean and with complete electronics. The guy said he ran it for 10 min, and it looks like it. I paid less than what the new kit costs, so I figure I can afford some upgrades.
And it is kind of an experiment, because I don't know how it'll handle on my track.
I'm kind of surprised by how quickly the cost of these things adds up. I shoudn't be, but... Just based on the size, weight, and simplicity of a 2wd, my brain insists they should be significantly cheaper than larger cars. But even if I went with cheap electronics, I could just squeak by at $600, and if I went Tekin RSX and mod motor, it'd cost me $800! (For comparison, I could build a sct410.3 with Tekin electronics for $900. A 1/8 buggy kit with Tekin electronics will cost ~$1,100, depending on the kit.
I guess I'm just a little prejudiced against the little trucks still? When I ran my Durango, it was my "cheap" truck...so I guess I'm still stuck thinking that a stadium truck should be significantly cheaper than bigger cars.
But I hope this thing really tears it up! It should be fun. I wonder if it'll be able to clear my crossover double jump? It is about 20'. (But I did design a short option, just in case.)
The $600 is if I bought the 22T 3.0 + cheap motor & ESC combo at Amain + cheap servo. I also included the aluminum bulkhead.
I actually paid $250 for the 1.0...and it comes with an orion 6.5t, [edit: Trackstar Turbo 120A ESC v1], turnigy servo. It isn't anything amazing, but I think it's a pretty decent package.
I actually paid $250 for the 1.0...and it comes with an orion 6.5t, (Orion?) 120A ESC, turnigy servo. It isn't anything amazing, but I think it's a pretty decent package.
