TLR 22 4.0
#152
Yes, Team Losi Racing
It will be available a little after the 22 4.0 hits the shelves, but on the way.
#154
final question on this issue, will we need TLR2062 Team Losi Racing Aluminum Front Camber Block to run the front bar? per JRMitch setup
#156
Hey Frank,
Will we still need to mod the front end for HRC or has this been addressed with the 4.0?
#157
#158
Weight distribution
Is there any info on the weight distribution and/or total weight of the car? Seems quite nice.
#159
Just working my way through the 22 3.0 and comments about putting the +3 hubs on and hrc block to correct rc at low ride height.
With kit ride height appearing to be 23mm, if i wanted to run 20/21mm ride height, would it better to use the +3 hubs and front spindle adjustment? In my mind this would keep the wishbone angle stock and rc and give the correct ride height.
Surface is grass in the UK of that matters.
Thanks.
Guess I would also need to raise the diff to get correct driveshaf angle. Looks like 20mm might be at the top of the carpet setup and bottom of the dirt set up.
Thanks.
You need to look at what is affecting your ride height.
At Norfolk Buggy Club in the UK we have both a grass track and a dirt track.
I find that ride height is affected by the tire profile; as the dirt tires like JConcepts flip outs have a higher profile than the Schumacher mini spikes.
On the dirt track I'll run around 22mm ride height and on grass around 19/20mm, the difference in ride height though is down to the tire profile and not how much I have wound the shock collar down.
For reference I use the LRC blocks on grass and dirt.
I can understand using the +3mm hubs, raising the diff and doing the spindle adjustment if running the HRC blocks, as they effectively lower the ride height by raising where everything pivots from on the chassis.
Not sure if that helps, or confuses, but that is my understanding, which may or may not be correct.
#161
Frank, if I was gonna run standup, what are the advantages of the 4.0 vs the 3.0 standup? Assuming I have the hubs and new spindles? Also how does the new chasis compare weight wise to the spec racer. And will any of thr new laydown stuff fit on the spec racer chasis?
#162
I've read that the 3.0 rear end will essentially drop into the 4.0, and I see a lot of shared components from the front of the Spec Racer 3.0.
Seems like you buy a 4.0 chassis and you are in the ballpark, minus some other front parts? I'd like to convert my 3.0 if feasible.
#163
TLRacing
#164
So other than the difference in hole location for the waterfall brace, could i fit the whole 4.0 rear end on a 3.0 chassis? Or are there too many changes? Reason being that i have a carbon chassis 3.0 thwt i have built up and want to continue using and im not afraid of drilling and countersinking some new holes.
#165
