Tekno RC EB48.4 Thread
#812
#814
So basically just like every other kit? Only thing is most other kits have cut outs for the velcro so the body sits flush
#816
They might stick out ever so slightly, perhaps .1mm at most. This is just due to the tolerances of the screws. Tighten them down and run it, any little part that sticks down will wear down pretty quickly. If you want you could also touch them with a dremel, shouldn't take more than a quick touch or two.
#817
I like to run a long strip of velcro down the whole side of the guards and a whole strip down the inside of the body. Fuzzy on the body
#818
The "little cutouts" I think you're referring to are just flashing from the mold. The SC uses the same mold but adds in the nerf bar mounts so when they're not there you see a little flashing.
#819
yeah i just put a little strip on each side about 1 inch. Bows it out a little bit but oh well lol
#820
#822
#824
Coming to the final stages. Basically ready to solder when I came to a discrepancy in the setup sheet.
Stock springs on the car are Black fronts and Orange rears. Set sheet says the fronts should be orange and the rears should be red.
What is correct? I've got the cambers and ride heights set but saw the issue in the setup sheet.
Also are you guys running the battery in the rear or front of the tray?
