Tekno RC EB48.4 Thread
#226
The Tekin T8 1900kv is a popular motor used in a wide variety of 1/8th scale electric buggies. I only state this to make the distinction to Tekin's T8i motor that has come up in this thread. The point I'm trying to convey is the size of the motor, based on its intended application. There are other brands of brushless motors that work the same.
The T8i is a smaller, lighter motor, more aimed at smaller, indoor tracks (hence the "i" in its name). While it will work, it can overheat when used outside of its intended use.
Also 1900kv is a common size chosen for 4S battery powered electric buggies. Some brands will list their motor offerings as 1850kv or even Tekin's slightly larger motor, the 2050kv. All will work, but the T8 1900kv choice is widely popular and works well with the Tekno buggy using either a 16 or 17 tooth pinion.
http://www.teamtekin.com/t8.html
http://www.teamtekin.com/t8i.html
#227
Since our facility's track is outdoor and large what would you recommend motor wise as it sounds like Tekins 1900 KV TBI is best suited for smaller indoor tracks.
Thus would their 1900 KV TB be adequate or HWings 1900 KV G2 motor? I am bringing up HWing as I have their new XR8 Pro ScT which is suggested as well for use in 4s 8th scale buggy racing.
Thank you very much.
#228
Tech Legend
The newer SCT410.3 so far has been excellent as I would expect from tekno and I look forward to seeing how it does outdoors, and it is nice to be back where the company puts a value on racing.
For your track which seems to be large you should be fine I am thinking. I would say in general if you have concerns, compare or talk wth someone who has a good running eb48.3 and a similar kv motor and determine what the theorectical top speed is. Then, plug that in using the new EB48.4 specs to determine what gearing you need. It may be to have a good gearing range, you want a motor with slightly less Kv than a 1900kv motor. That was something that some people I know (and I was considering myself) were doing on the ET48.3, using a 1700kv motor instead of the common 2000kv to have more gearing range on 4S.
#229
Thank you Cain much appreciated my friend. The lower KV makes sense thus I will ask some of the fellas whom race 8th scale at our local facility. I have a while regarding truly picking a motor as we are in the dead of winter, however hoping to head down to the HobbyPlex in Nebraska next month. From your info and all other info, I am thinking I will throw in HWing's 1900KV G2 motor, thus having the XR8 pro SCT speedo I really want to pair with a G2 HW motor.
#231
Tech Legend
I am also waiting to see if Maclan will have something for a 1/8 ESC. Not saying is wrong with my HW gear, but I always have a fond spot for Maclan.
This that new sensored motor? Looks pretty good and its Kv would be in a more reasonable range as far as the Tekno goes for where I race and my gearing habits.
#232
I'm also running the 2200 in truggy and am extremely happy with it.
#233
Yeah, ran in 2 big events so far and am happy with it. Doesn't have the "hit" a 1900 has and you can use a wider range of gearing without heat issues. I ran a 19t on the .4 last weekend with no heat issues.
#234
#235
Anyone try the Ruddog motors? I see the have a 1800kv motor. Price is sure affordable at $99,
#236
Thank you Jim much appreciation for your help. I am new to 8th scale racing even though the facility I run at has a very large 8th scale outdoor track I have always stuck with running 10th scale classes which predominantly are run on the smaller 10th scale track.
As long as you stick to the T8 sized motor can, it will come down to personal preference. I run Tekin and like Tekin. Their customer service is second to none and their performance on the track speaks for itself.
As many Tekin lovers there are out there, there are just as many HobbyWing fans, as well as a few other brands.
Check out what is in the pits. All of the major ESC's are programmable via a PC, tablet, phone or programming box (as well as buttons on the ESC). While not difficult to learn what these settings can do for you, it can be a bit daunting if you've never done it before. See if there's a "Tekin" guy or a "HobbyWing" guy that can help you set it up.
Jim
#237
Tech Legend
I hear u as the winter's really kill larger scal racing up in are area. I understand your spot for Maclan. I could not resist ordering their 10th scale MMax pro 160 when it popped up on Amain 2 days ago. Plus I needed another 10th scale ESC. Same here with my HWing XR10 pro stock spec and XR10 Pro 160 have been better than excellent. The little pro stock spec is a beast with the added quad cap. Just received another quad cap I will be putting on the XR10 pro 160. Looking forward to trying my XR8 pro SCT.
That quad cap does do wonders for sure
Curious on those as well including 1/10 lineup. great prices there, especially if you can sling in the new tower hobbies coupon match.
#238
I am hoping to run the new MMax towards the end of next week. It will be cool compare with the XR10 pro in which I will give my honest unbiased opinion. I have heard the MMax is super super smooth while having all the power in the world. One would think the 32 bit processor will make a huge difference.
#240
I've reamed many arms over the past 30 years. This was the first time I found an arm that was unreamable. my reamer wouldn't touch it. But the file worked great. I should have sent you my arms and my reamer and have you go at it. I spent an hour on one arm and got nowhere. It was like trying to saw a car tire in half with a stick. I even took the reamer bit out and stuck it in my drill. Then I froze the arm to make it harder in hopes of being able to get it to cut. Its a brand new Hudy reamer. The chainsaw file worked in a matter of seconds. Just trying to give people a heads up so when they build the kit they know how to get it right. And the problem is, the pin wont slide through. When the mold cools the two ends of the arm angle in toward the center and makes the holes offset, so its not a straight shot through the arm.
