Tekno RC EB48.4 Thread
#391
#392
Hey guys i just got the Tekno 23tooth aluminum servo horn for my Spektrum s6280 witch is 23 tooth and it will not go on. Any ideas?
#393
I had to use a flat head screw driver and separate the clap with the screw out to get mine on.
#394
any picture of a painted body ? black should look like a stealth jet !
#395
look like the new lot ha sbeen push back to late march now i just had alook on tower hobbies
#396
#397
#398
so.... I'm pretty happy with the car , but ive bent 2 shock shafts and a hinge pin already . what gives! I'm not a ruff driver no bad wrecks. coming from HB never breaking a part its getting alittle frustrating.
#399
You must of had just the right type of hit. Hinge pin + shock shaft, guessing on the same a-arm side? 1st time out for me this weekend and the beginning went a little rough, rougher than normal and all's well. The amount of teknos @ the track and the amount of wrecks I witnessed per heat & main with the cars still good to go.
#401
#402
all separate occasions 1 left front hinge pin 1 front right shockshaft and 1 left rear shock shaft
#404
#405
Another question guys. Ill be running the Tekin esc and 1900kv motor combo in this buggy and was wondering if this is the right pinion gear to get? Part number is TKR4176.
