Like Tree32Likes
HB Racing E817
Old 02-06-2018, 11:07 AM
  #676
Originally Posted by JRSlash
Does the HW Xr8 plus fit on this car? If it does, Does anyone has pictures of how tight it is. Don't really want to buy another esc.
Yes mate fits fine. It is tight but it's ok there is a small clearance
JRSlash likes this.
stalyoni is offline
Old 02-06-2018, 06:28 PM
  #677
tc5 man's Avatar
Originally Posted by turboboost
hi all
i m a veteran OFF road nitro driver, but are 2-3 year i m not on the hobby
now i want to return, with BLS 1:8 off road
what about problem on E817?? what about imminent upgrade? i see upgrade on the nitro version, they will come on the bls version? early? thak you so much
There’s nothing to really upgrade for ease the VRP rear suspension block that makes it easier to get to the diff which I may get . And the whole two diffrent Rear shock towers for more grip .
tc5 man is offline
Old 02-09-2018, 01:00 AM
  #678
the E817 is from november 2016. i think it will be upgraded this year, dont you?
turboboost is offline
Old 02-09-2018, 01:24 AM
  #679
Exclamation HB Racing E817 V2 1/8 4WD Electric Off-Road Buggy Kit
The E817 V2 1/8 Racing Buggy Kit!
https://www.amainhobbies.com/hb-raci...204271/p735075
Get ready, the E817 V2 1/8 scale 4WD electric buggy is coming soon from HB Racing. The “Version 2” of the E817 buggy is topped with a clear JConcepts Silencer buggy body and an updated molded nylon rear wing that is lightweight and more durable than polycarbonate wings. A narrow rear shock tower with revised shock length has been added for expanded range of shock adjustment. Updated machined aluminum 17.5° front caster blocks have been updated for extra strength. Updated aluminum steering linkage spacers replace the plastic spacers for improved bumpsteer geometry, more precise adjustment, less flex, and we revised the screw lengths to accommodate the updated spacers. Other updates include universal drive shafts, increased clearance ball end links, and updated body mounts.
Updated Features:
            ...very minor updates to an already awesome ebuggy
            TRiN is offline
            Old 02-09-2018, 10:03 AM
              #680
            SEF
            SEF's Avatar
            Trader Rating: 39 (100%+)
            I was hoping for the extended and updated chassis similar to the Nitro version. I wonder why they use the shorter chassis? The longer chassis made the nitro version planted. The E817 rear end is pretty loose and takes a good setup to get it planted. I would think the longer chassis would help things.
            Updated Features:
                      SEF is offline
                      Old 02-09-2018, 06:55 PM
                        #681
                      Have you tried the short carbon rear tower with the trusty front shock bodies? It’s supposed to plant the rear end.
                      jpas is offline
                      Old 02-10-2018, 04:15 AM
                        #682
                      This is true. I just changed to it on mine and now I need to make a slight adjustment to take rear grip out.
                      fbrk8r is offline
                      Old 02-11-2018, 09:38 AM
                        #683
                      Updated Features:
                                Damn it, I have an E817 and E817T in my garage that I just received from Absolute Hobbyz. Good thing it isn’t much of a difference.
                                gilbertfg is offline
                                Old 02-12-2018, 12:08 AM
                                  #684
                                lol i predict the v2 ahahahah
                                Old 02-12-2018, 05:23 AM
                                  #685
                                JRSlash's Avatar
                                I just got my e817 Saturday new and a new car came out... What parts are different on the v2?
                                JRSlash is offline
                                Old 02-12-2018, 01:42 PM
                                  #686
                                Lightbulb
                                204324 V2 Rear Shock Tower - NEW
                                67820 Long Shock End (4) - to work with the new V2 Rear Shock Tower
                                204141 Ball end 6.8 x M5 (offset) (2) - Increased clearance over 'straight' ball end links
                                204016 Universal Set Front - in-place of option CVD's
                                204015 Universal Set Rear - in-place of option CVD's
                                204269 V3 Caster Block Set 17.5 degree - strengthened over V2
                                204125 1:8 Rear Wing - in-place of Pro-Line Trifecta Lexan wing
                                204326 Buggy Bodyshell (Jconcept Silencer) - in-place of Pro-Line Predator body
                                ...and a bunch of alum washers for steering/ackermann plate locations instead of plastic
                                JRSlash likes this.
                                TRiN is offline
                                Old 02-13-2018, 12:39 PM
                                  #687
                                Lightbulb
                                Forgot to mention slightly longer hardware is used to 'store' all the bumpsteer washers (4 of them) and 'reset' the bumpster adjustment when changing between the 15deg, 17.5deg and 20deg caster blocks:
                                15deg caster - use 0mm bumpsteer washers on top, store all 4 washers on the underside of the ackermann plate
                                17.5deg caster - use 2mm bumpsteer washers on top, store the remaining 2 washers on the underside of the ackermann plate
                                20deg caster - use all 4mm bumpsteer washers on top
                                Z087 Flat Head Screw M3x20mm - previously Z086 M3x18mm
                                114489 Aluminum Washer 3x6x1.0mm Orange (20) - Part# of the washers mentioned in my previous post.
                                TRiN is offline
                                Old 02-13-2018, 10:55 PM
                                  #688
                                ha5
                                i got my kit on december, it whas all ready whit the v3 caster blocks
                                ha5 is offline
                                Old 02-14-2018, 12:08 AM
                                  #689
                                Thumbs up
                                Niiice! A running change to the kit...
                                TRiN is offline
                                Old 02-14-2018, 02:01 AM
                                  #690
                                stanleyw808's Avatar
                                Hello TRiN,
                                I would say it depends on the Kick-up setting as well..
                                Also if You change the B-Plate the bump steer need to be adjusted as well..
                                Cheers..
                                stanleyw808 is offline
