TLR SCTE 3.0 Thread
#976
Tekin 255 software is pretty amazing. extra smooth and the drive freq and torque settings allowed really come in handy when taming down the power or tuning to a feel you are looking for. I have not used the hobbywing stuff so can't comment on it other than I know guys you are please with the performance. I don't see a reason mixing is a problem.
Any chance we can get your tekin 255 s/w settings for the 4600kv? Your website has the older s/w posted.
Trying my old 4600kv out in my new 3.0 this weekend. Love the new truck! So easy to drive and a great bang for the buck. Now if TLR could only include some talent in the box also.....
#977
very new to SCT, just built this kit - stoked!
seeing LOTS of different opinions on motors....here and everywhere else. was about to pull the trigger on a tekin pro 4 HD then started finding a lot of ppl that like 2 poles...
any advice? the truck/motor will ideally fit two tracks (after tuning, of course) - an indoor, small (12-13 sec laps) med-high bite clay track, and an outdoor "1/8 scale" track that is currently being built-this will be a "medium-large" track and I'm not entirely sure what the surface will look like yet. as of now i'll be running the orion r10.1 (because I have it already.)
2 pole? 4 pole? either will work but why do you like one over the other?
thanks!!
thanks!!
#978
The large 2 pole motors are heavy and will take some time to tune the set up . They usually run warmer . They are usually a little easier to drive on a loose dusty track , but will not be good for a indoor tight track where the timing advantage is lost. The 4 poles are really the way to go. I will leave the esc discussion out this , but as far as motors go there are really only 2 choices , hobbywing or tekin . The trinity is out there , and so are a few left over novak 4 pole sc motors , but the HW and Tekin are the bread and butter motors . Since you have outdoors in your future , go with the 4700 or 4600. The HD 4300 is good too , hits batteries hard though and is a bit heavy. Then there are the 4000 kv motors . I run mostly indoors right now and the 4000 hw , with a 16t pinion , 10dg of timing, on a rx8 is more than enough . My motor has hit 160 , my esc without a fan has never hit 4 lights on the temp sensor. I wont run the 4000 Tekin pro 4 , I had one and it was always a disappointment. When I go back outside in the spring I will be going to a 4700 (or 4600 , whichever I get a deal on ) . The higher kv motors are more tractable in the hot dry weather , and they just plain jump long 1/8 double and triples better with the extra wheel speed. The hd4300 is more than happy inside or out , just gear up .
#979
Casper,
#982
I race with hundreds of short course racers. Not one of them runs a 2 pole. A 4 pole has double the torque. 2 poles rev higher on top, and feel smoother because they dont hit like a 4 pole does. Much harder to pull hard out of turns to clear big jumps with a 2 pole, and you have to drive smoother and carry you're mometum more.
If you're car is "spinning"... that doesn't have any thing to do with the motor. Thats your finger squeezing too hard. A 2 cell class like short course, you want as much power as you can milk out of your truck. 100c battery and a high KV 4 pole 550 is what 99% of my fellow racers run.
The only benefit to running a 2 pole would be the fact that they're dirt cheap. You can get an Atomik Red 550 2 pole 4400kv for $19.99. I used to run a 4400 and a 4800 2 pole and did okay with them. But they're not the best tool for the job.
#984
I saw Dakota Phend run his truck in person and it was absolutely ballistic with a 2 pole.
#985
Battery Spacing – This is certainly a personal preference or a setup type adjustment, but here are some starting recommended positions. A lot of it is based on the surface and the motor you run on. For those of you running dirt off-road tracks, we recommend using the middle position if using a 540 length motor and the forward position if using a 550 length motor. If running on carpet or Astro-Turf, it is one position back from each of those based on the motor size.
Does this change with the 3 degree motor plate?
#986
#988
Battery forward vs rear position on the 3.0
Thx,
Todd
#989
Those diff and shock settings are fine. Most important thing is getting better stiffer springs. Kyosho X gear Big Bores are the way to go if you're serious about performance. Or the TLR Silver rear and Brown fronts will be better. Battery in the rear, with the short ackerman is the best set up IMO.
#990
http://www.rctech.net/forum/14739098-post738.html
I have the 22 springs if you want them for free. 3 pack of fronts and the red and silver for rear, all new or less than 3 test lipos. Pay me for cost of bubble package, 1st class mail, paypal fees and they are yours. PM if interested. If Turbo doesn't want them they are up for grabs.
