Help with XXX nt2
Help with XXX nt2
Hey all,
Took my NT2 out for a run this arvo (fairly new to nitro racing) and after the first tank brought it in and filled it up and it wouldn't start.
I have noticed that the fly wheel is extremely loose with no resistance at all, is this normal?
More to the point though is what should i check as the reason that it won't start (glow plug is ok and getting enough charge).
Thanks.
Shags
Thanks.
Shags
Yeap, its your flywheel, you may want to try some locktight. when you turn the flywheel it should turn your motor over
Use locktite on the crank nut.Make sure you get it really snug,also since the flywheel loosened up make sure it didn't wear out the collet.
