TLR 22 3.0 Race Kit Thread! >
Like Tree26Likes
    Hide Wikipost
Old 08-23-2016, 10:37 AM   -   Wikipost
R/C Tech ForumsThread Wiki: TLR 22 3.0 Race Kit Thread!
Last edit by: Matt Trimmings
Cub86 posted the question: Hi. I'm struggling to understand the lay down situation. I run on high bite damp smooth clay and think the conversation would help on my surface but from what I'm reading I need to buy the lay down kit tlr338004. And the dirt gear case tlr332063. But do I really need both from what I've read the dirt case is 1-2mm higher anyway and u don't use the +3mm hubs or the front pivot hrc or Hrc mod. So is the dirt lay down kit tlr332063 is all that's needed to get me a lay down set up that's suited for clay With the components and car I already have. And if I only get the dirt case is there any problems that will need to be addressed IE.. bone plunge . I do know I'll need 1mm spacers on the waterfall to clear the battery. Thanks guys really trying to get my head around this.
Franks response:
Laydown Conversion will work great by itself. You run the aluminum +3mm hubs, the diff is +3.5mm, and you run the HRC front setup. Just follow a setup sheet from tlracing.com (Frank Root).
Dirt Tranny has the diff at the same height as the standard tranny case, and works with the standard plastic hubs. Both are +/- 0mm from stock. When you run this, no need to run the HRC front mod either.
I've found the stock laydown conversion parts to work great for most tracks. The dirt tranny is a great tuning option, but definitely not 'required'.
K.King
Something I made, pretty basic. Just to give people an idea.
Print Wikipost
Old 12-29-2015, 05:58 AM
  #1276
Davidka's Avatar
Trader Rating: 86 (100%+)
Originally Posted by Skeeter36
its stiffer than the supplied kit springs, although not far off. The silver kit front springs are fine but if you run indoors you will most likely enjoy a stiffer rear spring like a pink LF
Kit front spring is 3.18 which is a lot softer than kyo gold, which is farther away in range than the whole range from softest to stiffest in the LF set (which is very narrow). The non LF blue spring is 3.8 so TLR does offer a usable equivalent.
Davidka is offline
Old 12-29-2015, 07:00 AM
  #1277
rcus3r's Avatar
I too am baffled how folks are running Kyosho Golds (3.87) spring on their buggies?
Attachment 1337912
rcus3r is offline
Old 12-29-2015, 07:45 AM
  #1278
Davidka's Avatar
Mayfield brought the Kyo golds around with the 2.0. I believe Travis Amezcua ran the XXX with a really stiff (blue?) front spring too and that was even an RM car.
The kit front spring seems counter intuitive, like we should be running stiffer front springs for a mid-motor car but it's working well for me, even running the inside hole on the arm so I'm not really looking to change. I do plan to try the middle arm-hold and lower oil weight this evening.
Davidka is offline
Old 12-29-2015, 10:30 AM
  #1279
skrichter's Avatar
Attachment 1337912
KYO Gold is approx 3.30lb. Look at the next column on the chart. Noone would run it on 2wd if it was anywhere near 3.87 (way too stiff for dirt). Most common used buggy front springs for med/high grip dirt tracks range from 3.0 - 3.45lb.
skrichter is offline
Old 12-29-2015, 10:35 AM
  #1280
RC10Nick's Avatar
Originally Posted by Socket
Great write up. However, your wiring setup is atrocious. Is that a rat's nest? Do people really leave their cars looking like that? Good god!
Yeah, I guess it could be better. But what difference does it make other than aesthetics? Everything is safe and secure in there, there's just too much is all.
RC10Nick is offline
Old 12-29-2015, 11:21 AM
  #1281
oPAULo's Avatar
Looks fine to me Nick. Safe and secure.
Thanks for sharing.
oPAULo is offline
Old 12-29-2015, 11:59 AM
  #1282
Mayfield's setup is gold rear and white fronts. Their "measured" rating is only ever so slightly stiffer than the stiffest LF TLR springs.
RichD is offline
Old 12-29-2015, 01:46 PM
  #1283
Mudcat981's Avatar
TLR ORANGE standard Front spring rate 3.16 (measured)
KYOSHO WHITE front spring rate 3.22 (measured)
KYOSHO GOLD front spring rate 3.27 (measured)
TLR PINK LF Rear spring rate 2.14 (measured)
KYOSHO GOLD rear spring rate 2.14 (measured)
Mudcat981 is offline
Old 12-29-2015, 02:18 PM
  #1284
I stand corrected. I was going off TLR's figures for the springs, as not seen the measured ratings.
My main point was that no one seems to be using Kyosho gold fronts on set up sheets, just rears, but people seemed to be hung up on gold fronts for some reason.
RichD is offline
Old 12-29-2015, 03:52 PM
  #1285
Mudcat981's Avatar
Actually 3 of the setups call for KYOSHO GOLD fronts:
Jake Thayer - OCRC
JR Mitch - FZRC
Eric Willardson - Murf's IRCR
Others mainly used Silver LF fronts.
Old 12-29-2015, 06:36 PM
  #1286
I thought I read somewhere that Maifield's Setup was actually gold front springs and not white as listed...Does anyone have info on this?
FPMX772 is offline
Old 12-29-2015, 08:07 PM
  #1287
Vinny Cancilla's Avatar
I know on the 2.0 mayfield used gold fronts with white rears.
Vinny Cancilla is offline
Old 12-29-2015, 10:22 PM
  #1288
jt409's Avatar
I'm trying to gear my car for a 17.5 on a high speed track any suggestions on gearing and also I can't find any where that sells different sized spur gears for this car what are you guys using I tried to fit a b5 69t but it wouldn't fit. Thanks in advance.
jt409 is offline
Old 12-29-2015, 10:43 PM
  #1289
So I have had the car for a few week now and I have one problem with it.I can seem to get the on power push out of it.its not to bad indoors but for some reason outdoors it pretty bad.I have tried different setups on still the same end result, pushes.yes I have changed slingshot oils, shim placements, moving battery.could it be the fact im running the thin shorty packs. Or should I just get that brass weight for the front.
bolt speedman is offline
Old 12-29-2015, 11:10 PM
  #1290
Trader Rating: 73 (100%+)
I believe you'll have to go to the 2.0 spur and pads to get a 70.
lyork is offline
