TLR 22 3.0 Race Kit Thread!
#1096
I built the mod car's diff using Associated's silicone diff grease. Despite living behind an 8.5 it is still very smooth.
I made the change after hearing that AE's grease was of a higher quality for the application. My experience is confirming that claim.
I build the diffs exactly the same way every time and follow a typical break-in procedure before setting the final adjustment.
#1097
I have built two 3.0s now. The first one I built for stock, the second mod. The diff in the stock car became slightly gritty as you say. I rebuilt it and it is slightly gritty again. Not a disaster but rather just noticeable.
#1098
The short answer is that the car is rolling too much. If you consider that many are running the rear shocks with 31mm + of travel (as I am) you know the car is rolling a lot if it can pick the wheel up with that much travel. Some have dealt with that by using firmer springs or going up in oil wt. On smoother tracks this is probably a good call. I am dealing with it by using the "A" position for the ball stud on the rear hubs. I don't want to stiffen up the rear suspension too much on our track because the car will start bouncing around.
Going to the "A" ball stud mount position raises the roll center and also increases camber gain so you may also want to run a little more negative camber. I used -2 knowing I might give up some forward bite. But this car isn't lacking in that department at all.
This adjustment improved the rear inside wheel lifting and subsequent diff-out.
#1099
I built with the kit's diff lubes and my diff is as smooth as any ball diff I've ever seen, TLR or otherwise.
#1101
The diff lube is meant to do lubricate the ball against the plastic diff gear, while allowing friction between the balls and diff rings, ie. It has very little film strength. Smoothness is almost entirely dependent on how smooth the surfaces of the balls and rings are and not bottoming out the diff spring.
#1102
It is a myth. Neither company "makes" their own lives and it's more likely that they get them from the same place.
So many products are simply re-branded, pop out of the same factory.
Also, I've noticed no people/ groups/ publications seem to do real, critical testing between products anymore. Is everyone so scared of getting sued that no one is willing to compare products like motors, batteries, grease, tires, etc. with actual tests? Everything I read is thinly veiled advertising at worst, or simply unfounded opinion at best. :/
#1103
We run slicks at my track and the grip is pretty high. I also noticed the inside rear wheel lifting.
#1104
A shorter link also lowers the roll and stiffens the car up. There are will react faster with the shorter link. Going to a longer link on a high bite track should tame the car down by slowing down the reaction.
#1105
I went from a B5M with an assortment of upgrades. MIP 3 Gear, MIP Top Shaft, Titanium Turn Buckles, and an assortment of tuning and other little upgrades. To the TLR 22 3.0 out of box parts and I find it to be a night and day difference. The TLR is so much easier to drive and jumps just perfect. Just my opinion of course
#1106
calling on frank root!!
Will the aluminum front camber block from the 22 2.0 fit on the 3.0?... How accurate is the hop up section on the tlracing web site. For example a part is in the 3.0 hop up section but beside the part pic, name and description it shows " 22 2.0/ 22SCT, and/or 22T.....but not 3.0. Any help would be great....thanks
#1107
#1109
Did anyone notice the manaul does not mention anything about cutting the wing to go around the shocks?
#1110
Can someone explain the wing spacer thingy that has 8 degrees on one side and 0 degrees on the other. If it is to change the angle of the wing, than should it not be on the underside of the wing and not on the top? And if it's not for wing adjustment, than what is its purpose?
