TLR 22 3.0 Race Kit Thread!
#3121
Has anyone tried the dirt lay down tranny with the 3mm hubs? It looks like it gives almost zero dog bone plunge, good or bad?
#3122
Seems like I searched for the wrong words...
#3123
#3124
If you can afford it get the serpent gear diff. The losi is for the RTR and it performs like it. Three .3 shims on either side.
Part# SER500192
https://www.amainhobbies.com/serpent...500192/p269224
Part# SER500192
#3125
Does anyone know what body is used in the 2nd photo of the Exotek lay down, on their website? I don't think it's a TLR body...?
http://www.exotekracing.com/22-3-0-l...ox-conversion/
#3126
#3128
The yz body is the only one I use now for both my cars the standard or lay down.
#3129
Is the lay down transmission conversion good for all surfaces? My understanding is that you wouldn't want to run that in lower grip situations, correct?
#3130
It's designed for high grip conditions where you already have more rear grip than you know what to do with. If your on medium to low grip then stay stock
#3131
If running the dirt tranny I would stick with the standard hubs. I tried the dirt tranny yesterday at Norcal yesterday with good success. Really liked it!
#3132
For lower grip situations I would stick with either the 3 or 4 gear standup transmissions. The laydown works really good on medium bite with the right setup and on high bite it is amazing.
#3133
Is the laydown transmission internal gear ratio the same as the stand up ?
