Tekno RC EB48.3 Thread >
Like Tree22Likes
    Hide Wikipost
Old 03-13-2017, 12:03 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Tekno RC EB48.3 Thread
Last edit by: MattDub
Welcome to the EB48.3 Wiki
What option parts should I consider buying with a new kit?
None are required but we recommend the following:
Springs:
Low Grip Track:
TKR8772 – Yellow Low Frequency Rear Springs and TKR8762 – Grey Low Frequency Front Springs
Low to Medium Grip Track:
TKR8773 – Orange Low Frequency Rear Springs and TKR8763 – Black Low Frequency Front Springs
Medium to High Grip Track:
TKR8774 - Red Low Frequency Rear Springs and TKR8764 - Pink Low Frequency Front Springs
TKR5199B – HRC Rear Hubs (L/R, CV or uni, EB/NB/ET/NT48/48.3) - Improves stability of the rear on mid to corner exit. Able to be on power earlier on corner exit.
TKR6146 - CNC Delrin Shock Cartridge Set
TiNi Shock Shafts
-TKR6017T (front)
-TKR6061T (rear)
This car is very durable. Here are the spare parts that I recommend you keep on hand:
TKR5020 – Hinge Pins (inner, front/rear)
TKR6061T – Rear Shock Shafts w/ TiNi Coating and TKR6017T – Front Shock Shafts w/ TiNi Coating
TKR5286 – Front Suspension Arms and TKR5184 – Rear Suspension Arms
TKR5194 – Spindle Carriers
TKR6009 – Shock O-Ring and Bladder Set (for 2 shocks)
Tips and Tricks
List of Vehicle Setup Adjustments and Build Tips can be found here. There are several videos and articles detailing the building of shocks, diffs, camber links, etc.
Page 3 Step K-3
Put the screw in upside down so that the head of the screw is in the hex spot that's molded into the spindle. This will aid in clearance in full droop / full steering.
Page 12 Step I-2
Use no less than 4 shims on the steering spindle to limit steering throw. I actually just use one 2mm ball stud washer from my 10th scale stuff since each shim is .5mm.
Setup Sheets:
Setup sheets for all Tekno RC vehicles can be found here.
Warranty Policy:
Tekno RC is the only company in the industry that will give 50% off of parts if returned to them using the General Warranty return policy found on their website. The parts can be lightly used or completely abused, as long as the part is still being produced it's covered!
Piston Drills:
Some of our setups recommend using pistons that are enlarged. For instance 4x1.9 or 3x2.0. To drill the pistons we recommend the following:
GMK Supply Piston Drill Set
16PC Metric Bit Set Metric Sizes 2.00 to 3.00 MM.
Print Wikipost
Old 10-31-2015, 12:34 PM
  #586
rcgod's Avatar
Trader Rating: 33 (100%+)
Originally Posted by EricM
Is there a battery manufacturer that you could recommend? Like reedy glacier, etc. What discharge like 30c or 45c?
I would go with 50c and up. Smc, promatch, protek, reedy, and vant have all worked well for me. Great price on these:
http://thebarnfloor.com/catalog/prod...oducts_id=5902
rcgod is offline
Old 10-31-2015, 02:37 PM
  #587
Thanks for all your advice.
Eric
EricM is offline
Old 10-31-2015, 07:33 PM
  #588
justpoet's Avatar
Trader Rating: 16 (100%+)
There are many good batteries and companies (as well as many bad ones). One of the best bang for the buck companies to deal with is generally SMC. Either the 5200 or 6500 packs here are fairly common in eBuggy vehicles. I generally run the 6500 as I will never ever worry about power or the pack being stressed or being able to make time even if the main is long and there is a long warm up period and long after lap in a qual. The 5200 should balance the vehicle more side to side, though I haven't found problems from that with the 6500.
http://www.smc-racing.net/index.php?...ory&path=67_96
justpoet is offline
Old 11-01-2015, 08:11 PM
  #589
HPIFreak's Avatar
i know this has probably been asked before, but im not having any luck finding anything. is there a list of things to buy to update the EB48.2 to the EB48.3 or does someone sell everything as a kit? my .2 is ready for retirement after a full season of outdoor, and i can either drop $500 on the .3 or spend a few hundred and restore my .2 but if im going to be buying parts for my .2 id rather just upgrade it to the .3 if thats possible but i dont know all the little tiny details that are different and what goes with what because they changed so much
HPIFreak is offline
Old 11-01-2015, 08:56 PM
  #590
lala4fire's Avatar
http://www.fiercercsolutions.com/main.sc
Go to this website. They have the basic conversion and more.
lala4fire is offline
Old 11-02-2015, 04:59 AM
  #591
MOE
MOE's Avatar
Trader Rating: 14 (100%+)
This is information I found on tekno's site
EB48.3 New Parts Listing
Part # Description
TKR5006 Chassis (7075, hard anodized) *Small change to the droop pad area
TKR5071X Wheel Hubs (aluminum, lightened, gun metal ano, w/pins, 2pcs, EB48)
TKR5161 V2 Adjustable Hinge Pin Brace ("A" block, 7075 CNC aluminum, EB/NB/ET/NT/SCT)
TKR5162 V2 Adjustable Hinge Pin Brace ("B" block, 7075 CNC aluminum, EB/NB/ET/NT/SCT)
TKR5163 V2 Adjustable Hinge Pin Brace ("C" block, 7075 CNC aluminum, EB/NB/ET/NT/SCT)
TKR5164 V2 Adjustable Hinge Pin Brace ("D" block, 7075 CNC aluminum, EB/NB/ET/NT/SCT)
TKR5165 V2 Hinge Pin Inserts, Wheelbase Shims (EB/NB/ET/NT/SCT)
TKR5166 Front Bumper (revised, EB/NB/ET/NT)
TKR5174 Rear Arm Mud Guards (for TKR5184 & TKR5515, EB/NB/SCT)
TKR5181 Low Profile Wing Mount & Body Mounts (EB48/NB48/EB48SL)
TKR5184 Suspension Arms (rear, EB/NB48.3) *New Geometry
TKR5187 Rod Ends (straight, 6.8mm, EB/NB/ET/NT48, 8pcs) *Straight = less flexing
TKR5191 Tapered Driveshaft (center, front, 7075 aluminum, black ano, EB48/ET48) *Stronger/truer
TKR5193 Spindles (trailing, L/R, requires TKR5194, EB/NB/ET/NT48, EB/NB.3) *New Geometry
TKR5194 Spindle Carriers (trailing, 15 degree, L/R, EB/NB/ET/NT48, EB/NB.3) *New Geometry
TKR5199 Rear Hubs (L/R, CV or uni, EB/NB/ET/NT48, EB/NB.3) *New Geometry
TKR5259 Decal Sheet (EB48.3)
TKR5260 CNC Split Cntr Diff Mount (mtr mnt only, 7075, gun metal ano, EB/ET/SCT)
TKR5263 Split Cntr Diff Mount (composite, requires TKR5260, EB/ET/SCT/SL)
TKR5268 Shock Tower (front, 7075 CNC, gun metal ano, EB/NB48.3) *New Geometry
TKR5269 Shock Tower (rear, 7075 CNC, gun metal ano, EB/NB48.3) *New Geometry
TKR5286 Suspension Arms (front, EB/NB48.3) *New Geometry
TKR5491 Sway Bar (2.4mm, rear)
TKR6003 Shock Caps (aluminum, gun metal ano, 2pcs, EB48)
TKR6033 Shock Spring Set (rear, 1.4 x 9.5T, 85mm)
TKR6048 Shock Spring Set (front, 1.5 x 9.5T, 65mm, black)
TKR6060 Shock Body (rear, x*long, aluminum, hard ano, 2pcs)
TKR6061 Shock Shafts (rear, x*long, steel, 2pcs)
TKR6140 Locking Shock Rod End and Spring Perch Set (EB/NB/ET/NT/SCT)
TKR6144 Shock Boots (long length, rear EB/NB/SCT, front ET/NT, 2pcs)
TKR6145 Shock Boots (X*long length, rear EB/NB, 2pcs)
TKR1238 Droop Adjustment Screws (M4x10mm, 8pcs)
TKR1240 Lower Shock Mount Screws (2 CW thread, 2 CCW thread, EB/NB/SCT)
TKR1605 M3x10mm Set Screws (black, 10pcs) *May not be needed. Included with TKR6140
MOE is offline
Old 11-02-2015, 06:12 AM
  #592
Thumbs up
hi eb48.3 guys,
someone a good shock setup for loamy, bumpy,outblown tracks?
i think, that the orange spring in the rear is to hard, with stock setup(450oil, 1,8x4piston)
scgu is offline
Old 11-02-2015, 10:21 AM
  #593
Originally Posted by scgu
hi eb48.3 guys,
Take a look at Joe's setup from Wicked. A lot of guys are running the same setup on both the NB and EB (benefit for those that drive both) with similar driving styles. You might have to soften up the rear a bit if it's blown out. I'm currently using yellow and 450.
http://www.teknorc.com/tekno5/wp-con...0Bumpy_Dry.pdf
RokleM is offline
Old 11-03-2015, 12:03 AM
  #594
Thanks.. Ok.rear softer.And you drive pink in front ? Pink is a little bit harder as black ...
scgu is offline
Old 11-03-2015, 05:40 AM
  #595
I was referring to Joe's setup if you wanted to give that a try. I found the back end a little stiff and went slightly lighter on oils and springs.
RokleM is offline
Old 11-03-2015, 01:14 PM
  #596
To get the basics of the .3 on your .2, go here. http://www.fiercercsolutions.com/Tek...kit-FRC010.htm
That kit will give you the new suspension geometry, but you won't have full .3 adjustability. That being said, just the upgrade is a NICE addition.
To get the suspension adjustability, go here. http://www.fiercercsolutions.com/SCT...kit-FRC008.htm and that will complete you, so you can use all the .3 upgrade sheets.
Only other thing that isn't necessary, but is nice, is the split center diff. http://www.fiercercsolutions.com/TKR...un-TKR5261.htm That's for the aluminum one. They have a composite that will save you a few bucks. But if your gonna spend the money, just do the aluminum.
ezlight is offline
Old 11-05-2015, 10:10 AM
  #597
I just got my kit. The build seems pretty easy to follow and build.
EricM is offline
Old 11-05-2015, 03:36 PM
  #598
Carter Flotron's Avatar
Just take care not to over tighten screws, and it should be a piece of cake. Let us know if you have any more questions
Carter Flotron is offline
Old 11-05-2015, 06:06 PM
  #599
8ight-e's Avatar
Trader Rating: 58 (100%+)
Just grabbed .3 kits (eb,et,sct) are there any part issues still drive shafts etc to worry about or is all that fixed? I'm not going to be able to race these kits until Rama in Feb so I'd like to get ahead of issues so I can have Fun racing at the event. TY Several guys were having issues w/ shafts at the end of the summer locally, only reason I'm asking.
8ight-e is offline
Old 11-05-2015, 06:31 PM
  #600
Trader Rating: 21 (100%+)
All fixed.
MX304 is offline
