Tekno RC EB48SL Thread
#50
#51
eBuggy has a minimum weight limit of 3200g
eBuggy lite has a maximum weight limit of 3200g in most rule sets.
Some rule sets include limiting to 2s and/or short course motors as well.
There is no roar or ifmar class for this though, so these have been general rules adopted across many tracks. Other rules in the class for things such as dimensions match the full normal eBuggy rules.
#52
Side note: most ebuggies can make that lite weight by swapping to sc motor and normal 2s battery size, though some need additional light or missing parts. Tekno can easily go between the two as it was designed to be near the minimum weight to start with for the full eBuggy EB48.
#54
How far from that would you be with the "regular" eb48? If you can't take advantage of the sl's light weight then it seems more sensible to get the standard buggy's strength and part longevity advantage to me.
#55
Tech Legend
we may even start a class like this I am thinking, but that is secondary.
Also, I want to share parts here as well.
#57
Tech Legend
This year will try vipers VF4500 motor as I am hearing for a 540 it feels close to the HW.
#58
Use a 550. These are 6+lbs and the wheel/tires are larger diameter than an SCT's. Better to have a little extra and dial a little out with the current limiter than to run a 540 closer to it's load limit.
