Yokomo YZ-2
#2701
A lot of us run the 62mm axles and have no issues, so wondering if you have installed something incorrectly.
#2702
Did you build the diff correctly or maybe not tighten it down enough? Do you have the spacer on the correct side of the axle?
#2703
the kit comes with the 60.50 shafts and i have 2.5 degree negative camber .also the spacers 2x were intalled in the shocks. also the spacer your talking about is the one between the 2 bearings?
#2704
That is interesting! Maybe I have not looked hard enough. In talks with some chassis sponsored drivers at my local track, I was under the impression that there are some rules that need to be followed otherwise sponsorships could be revoked. From the examples you have it appears that "crossing the streams" is needed at time to achieve the best setups.
Now running tires from other than your tire sponsor appears to be a no-no unless you've got to run a control tire at the event. But that makes sense. Running someone else's tires would be the equivalent of running a Kyosho buggy with a Kyosho sticker on it when your shirt says, "Yokomo". Quite different!
#2705
#2706
Sounds like you assembled the diff incorrect. Also.too much neg camber will cause this aswell
#2707
thanx guys all sorted . diff to loose
#2708
why are some not running a rear bumper? weight or flex?? or just to make me research?
#2709
is there a link to Maifields set up from reedy race??
#2710
#2711
Fantastic first practice session
I dont know why i waited so long to switch (actually i do, tax return lol) im very impressed by how well the ca handles on clay with just a few adjustments to the stock setup.
I do however want to do a little more work on reducing rotating mass so i can get more out of my motor. So my question is whether the ae diff will fit in the yz2 so that i may use pucks.
#2712
with the cars near all being metric so much is interchangeable and near anything seems possible.
the AE B5m worlds car photos i saw was alot of yokomo. recent photos of the reedy race showed various rear hubs and outdrives used on AE cars, some looked like re-anodized versions of existing hubs other cars use. there are posts of AE drivers using TLR bones with etc parts
ae and yok use 52T diff gear. most 2wds use the same size diff support bearings, so use of another brands diff may come down to just shimming. you can probably use one, but may have to use the AE hub or after market carriers
there was a xray XB2 posted somewhere that had TLR diff, TLR aluminum bones, TLR outdrives and TLR hubs set up for stock racing. the wiki on XB2 shows setting up a puck system using older MIP yokomo parts. seen TLR posts of racers using serpent diffs, etc
yokomo picked up some key drivers, so if the demand picks up on the car, maybe MIP will fire up the lathes again?
#2713
Hope so. I found out though a little research that the ae outdrives will bolt onto the yz diff and that by using the new offset hubs i can use b6 bones. The b6 ones are a half mil shorter than the yokomo offset ones but it should work ok.
#2714
I do however want to do a little more work on reducing rotating mass so i can get more out of my motor. So my question is whether the ae diff will fit in the yz2 so that i may use pucks.[/QUOTE]
Page 120 onwards will help you out with that.
#2715
Fitting YOKOMO BALL DIFFERENTIAL KIT ( Z2-500 ) to original YZ2
My local carpet track closed down and i'm keen to to convert my first gen. YZ 2 with gear diff to run on the dirt the best I can... Can I fit the YOKOMO BALL DIFFERENTIAL KIT ( Z2-500 ) to original YZ2??
Thank in advance.......
