Hyper 7 starts but dies as soon as throttle taken up!?
I've just got a hyper 7 and have ran it through two tanks of fuel on idle and low revs. I went out this morning with the intention of giving it a first 'easy' run but it kept cutting out as soon as I took the glowstarter off. I assumed the mixture was too rich and fouling the plug so leaned the main high speed adjuster AND the low speed a little. I could finally get her to run of her own accord but for love nor money I could not get the car to rev. As soon as you tried to apply some throttle it would cut out. I fiddled with all the settings leaning her some more and that didn't work. I figured I'd gone too far and richened it up a little and still the same problem and a lot of oil out of the exhaust after I shut her down so I leaned her right up again to no affect. I then put the car back to the factory settings, which it used for first 2 tanks, and still no joy?!
I'm assuming the car needs a setting different from the factory run in settings now that its been through two tanks, but what? Why is she cutting out on throttle? To rich/lean?
try a new plug that's what my wife hyper did . she uses a o.s. 8 plug
Manged to sort it Put her back to the factory settings and then adjusted it slowly to lean her out a little until finally she responded and off I went. Had a great time today even though I'm still taking it quite easy to run her in. Had some air too
you still might want to put a new plug in...you might have it too lean now just to keep it running...
That's quite normal at break-in. Next time when the engines running, leave the glow ignitor on for a few miniutes.
How many tanks has the engine been through so far?
Sean
Sean
Now on around its 15th-16th tank of fuel....and now with uprated high torque servo's, a better power set up and with other bigs on teh way. Uh-oh, I've got the bug
Sean
