Old 09-18-2005, 12:43 PM   #1
Default Hyper 7 starts but dies as soon as throttle taken up!?
I've just got a hyper 7 and have ran it through two tanks of fuel on idle and low revs. I went out this morning with the intention of giving it a first 'easy' run but it kept cutting out as soon as I took the glowstarter off. I assumed the mixture was too rich and fouling the plug so leaned the main high speed adjuster AND the low speed a little. I could finally get her to run of her own accord but for love nor money I could not get the car to rev. As soon as you tried to apply some throttle it would cut out. I fiddled with all the settings leaning her some more and that didn't work. I figured I'd gone too far and richened it up a little and still the same problem and a lot of oil out of the exhaust after I shut her down so I leaned her right up again to no affect. I then put the car back to the factory settings, which it used for first 2 tanks, and still no joy?!
I'm assuming the car needs a setting different from the factory run in settings now that its been through two tanks, but what? Why is she cutting out on throttle? To rich/lean?
Saxo Boy is offline   Reply With Quote
Old 09-18-2005, 05:50 PM   #2
never lift's Avatar
Send a message via AIM to never lift
try a new plug that's what my wife hyper did . she uses a o.s. 8 plug
never lift is offline   Reply With Quote
Old 09-19-2005, 11:37 AM   #3
Manged to sort it Put her back to the factory settings and then adjusted it slowly to lean her out a little until finally she responded and off I went. Had a great time today even though I'm still taking it quite easy to run her in. Had some air too
Old 09-19-2005, 12:12 PM   #4
losi jon's Avatar
you still might want to put a new plug in...you might have it too lean now just to keep it running...
losi jon is offline   Reply With Quote
Old 09-23-2005, 09:44 PM   #5
Team Duratrax's Avatar
Send a message via MSN to Team Duratrax
That's quite normal at break-in. Next time when the engines running, leave the glow ignitor on for a few miniutes.
How many tanks has the engine been through so far?
Sean
Team Duratrax is offline   Reply With Quote
Old 09-24-2005, 05:46 AM   #6
Now on around its 15th-16th tank of fuel....and now with uprated high torque servo's, a better power set up and with other bigs on teh way. Uh-oh, I've got the bug
Old 09-24-2005, 09:56 AM   #7
Replace the glowplug.
Sean
My Nitro RS4 RTR 3 EVO Starts then dies !! help. yoshi_sx Singapore R/C Racers 1 12-26-2005 05:09 AM
My engine dies at full throttle, any ideas? Prozak Nitro On-Road 13 02-18-2004 06:58 PM
motor dies tdragon Electric On-Road 4 05-19-2003 03:40 PM
engine dies tjrcs Nitro On-Road 1 05-17-2003 12:23 AM
When i when i take off the glo igniter it just DIES!?!?! BlakeH Monster Trucks 6 04-26-2003 10:39 PM
