VBC Racing Firebolt DM 2WD buggy kit
#331
Everything about This car screams quality on paper and also when you build it. I got 2 new bulkheads to try out tomorrow. If it holds up and perform I am a happy camper. If not I am going X-ray, while waiting for a d215. :-)
#333
Second time at the track with my firebolt today. I got about 10 laps before an idle gear stripped. No biggie, was expecting that, but maybe not so soon :-)
Tore the gearbox apart, cleaned out all the plastic bits in there and mounted the aluminium gears. Run about 5 packs and the car handled really good! Nothing broke! Horay!
After analysing last weeks wreck I glued the lower bulkhead together with the center bulkhead. This will hopefully stress the area around bulkhead holes less. See image.
We are running on carpet with slicks here in Sweden during the winter.
I was using mostly stock setup with 35 wt Ass oil in front and 32.5 in the rear.
I use a Yokomo geardiff, that fit right in. I also mounted the brass arm mount for some more steering. Going to do some more tuning next week. But this car drives fantastic right out of the box.
#334
R/C Tech Elite Member
Running the car on med/low bite clay. Took about 3 packs before the filers went, car is still way quite withthe aluminum gears. I had an eclip in one of the shock bodies come off no biggie most likely builder error. I actually got the rear arm caught on a pipe nail and it broke the head off the screw that holds the lower XR mount on and the mount slipped off, kinda crazy thing lol. Switched to the carbon chassis for 17.5 class. First night took the win in exp 17.5 buggy at my local track. No issues with bulkheads yet. Super happy with the car so far.
#335
Dove mine for first time yesterday and Wow it handles nice . I did hit a pipe with hole in the dirt so wheel really got caught and I broke the front arm mount I might get aluminum one next . also I spaced lower rear shock mount with a 2mm washer but all full compression it rubs on inner rear wheel , might have to go with 1mm spacing
#338
The front and bottom bulkheads are weak-sauce on this kit. It, besides the idler gears are the only issues I've had with the car. Excellent steering and control. I've been running it on medium grip indoor clay with great results.
I'm not sure if anyone has mentioned this but 22-2 aluminum idler gears are a direct fit and actually make the car a touch quicker.
I love the car but I'm having a superb issue with parts support here in the US. As a result I'm going to continue running the Firebolt but make it my number 2 until I can get consistent parts support here. VBC needs to step up the distribution network and availability.
#339
www.discountrcstore.com
www.superiorhobbies.com
As far as the front bulkheads, VBC Racing is very aware of the issue. Newly updated parts and materials as well as an aluminum version are supposed to be available in December.
#340
Of course it would be much better not to experience such problems at all, but as the FBolt ist VBC's first off-road kit ever, I am willing to cut them some slack.
#341
I had a similar issue when trying to remove one of the screws. It seems very tight. Not sure what can be done since they are bearings and metric screws.
#342
Attention Firebolt DM owners. VBC Racing is providing replacement aluminum idler gears for all Firebolt DM kits. Send an email to [email protected] with your name, address, and proof of purchase and we will ship you a set of aluminum idler gears.
#344
Must be the wrong bearings, I did not have any such issues with my steering rack. However, my rear hexes came with too small screws; no biggie, had some correct ones in my box.
