Kyosho Scorpion re-release
#122
#124
I believe the wing is from a Losi XXX. I found it in a old box of parts.
I tried to paint the stock plastic wing but the result was not good.
The Flash is a 15x2 too! A friend gave it to me, it is like new.
#125
Looks great..
#126
Cool, are those shocks better quality or just longer with more volume do you know? Do you have to use the CF shock towers with these shocks? I just put in an order for some of those universal shafts from Banzai and it said in stock but they said they can't supply, odd?
#127
Banzai often does job orders. So that they don't stock too much inventory. That's how they keep prices down.
The HG shocks are higher capacity and longer; so you will need the longer shock towers. They can also be bled from the top, like modern shocks.
I decided to buy the longer towers in Aluminium from Pargu. To me, the carbons look odd on an 80s based car
#128
#130
[QUOTE=Raman;13691993]Banzai often does job orders. So that they don't stock too much inventory. That's how they keep prices down.
You must be right there, I put in another order for some tyres and bits they showed in stock again, I was supplied one part out of the lot . Obviously I'll have to click backorder if I want anything lol.
#133
Here are some updated picts with Pargus parts. My roof is not perfect either, but it will be a runner so I'm not that concerned. It's too bad he doesn't counter sink the holes like the 2014. I did it myself, however I messed up on the ones that are on the bed.
Front shock towers with standard shocks
Rear shock towers with test fit of TRF shocks.. No go!
Now I just need to wait for my HG shocks to arrive from Banzai
#134
Thank you for the pics. I fitted vintage AE shocks on mine, on the stock locations. I had to dremel a bit of the rear tower so the rear shocks could clear it, maybe you could do the same?
#135
Cool, I was wondering if AE shocks off the old RC10 would fit as I'm sure I have some floating around somewhere.
