IFMAR Offroad Worlds Winner?
#302
A little disappointing turnout for Schumacher eh Adrian? or was nothing panned out for this years worlds? I know Simon and Rich was there with the new Cat but with the design that everyone seemed to go with on the 4wd it would seem to have stuck it out with the Cat3k?
#303
On the German forum there was a comment from one of the drivers regarding the 5 cells. It seems there was no grip at all at the track so the 5cell batteries helped a lot. The 6th cell just was used for weight distribution.
#304
so, why not just go back and use some old 2400's then?
Seems crazy that the battery companies spend all their time and money developing faster and longer lasting batteries only for us to go take a cell out.
But, I guess whatever works.
Me, I would think just turning the torque right down on your speedo would work.
#305
Yeah and whats the Slipper for?
#306
I would think the 2400's would have still to much voltage.
#307
this wasnt just a normal club race, if you look at the level of driving experience, and think about the suport (electronincs mfg, motor mfg, and car mfg) that was available all week, it seems like adjusting the slipper or speed control probably just wasnt enough, pretty tough group of racers there to second guess....jmo
#308
#309
I remember when trucks were first run, everyone ran 7 cells and 11 turns. Then one day at a high bite track, the 7 cell factory guy was passed by a 6 cell truck and a 10 turn. Way easier to drive fast. I woudl suspect dropping to the 5 cell configuration, just made it way easier to drive fast without loosing much top end at all.
#310
Originally Posted by T. Thomas
Slippers are not designed to be used as a traction control. It was designed to increase the life of the diff. When the rear tires bounce around under heavy acceleration, or under heavy power when landing, if the slipper did not give, people would be rebuilding the diffs 10 times as much. A loose slipper will reduce wheel spin, but when the pads heat up tey will just lock up and this in a very inconsistant feel. Anything beyond 2 foot of slip is hard to be set consistant, in my opinion.
#312
If you adjust the slipper, you won't get any drive to take the jumps, just won't work, you're not in full control either.
Having raced at that track at last year's off rd Euros, i can understand why they have done this. There is so little traction out there.
#313
Far as im concerned Traction control is illegal in rc electric racing period!! And so Slippers were made primarily to limit the amount of torque from the motor onto the tyres not to save the diff which is the most ludicrous thing ive heard in a while. Yeah it does help the diff on the way but thats not what the slipper is for in the first place.
