Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread >
Like Tree35Likes
    Hide Wikipost
Old 01-24-2018, 07:02 AM   -   Wikipost
R/C Tech ForumsThread Wiki: Kyosho Lazer ZX-6 & ZX-6.6 4WD Thread
Last edit by: alex4r
Kyosho ZX6.6 New Parts (* = required to update ZX6 to ZX6.6 platform)
LA359B - Center Mount Set (ZX6.6)*
LA375 - Center Diff. Gear Set(ZX6.6)*
LA375-01 - Center Diff. Gear Case Set(ZX6.6)
LA375-78 - Spur Gear(48P-78T/ZX6.6)
LA376 - Center Drive Shaft (71.5/ZX6.6)*
LA377 - Center Drive Shaft (79.5/ZX6.6)* (x2)
LA378 - Center Drive Shaft (88/ZX6.6)*
LA379 - Joint Cup Cover (ZX6/ZX6.6)*
LAW54B-01 - HD Chassis*
LA355B - Side guard set*
UM713B - Rear Arms (from RB6)*
UM561 - Outer rear hinge pins*
LA236-12B - 1.2mm Front sway bar*
LA351B 4-hole front shock tower*
Options
VVC Blades TFW126
Spare Blades TFW001-01
Manuals
Lazer ZX6.6
Lazer ZX6
After Market Bodies
JConcepts Silencer
Weight Reduction options for 13.5 Class
Chassis:
UMW711B - Carbon composite rear arms
LAW60 - Carbon composite front upper bulkhead
LAW61 - Carbon composite rear upper bulkhead
LAW52 - Carbon composite front chassis brace
LAW53 - Carbon composite rear chassis brace
LA209HB - Carbon composite gear boxes (pinion bearing retainer & upper gearbox half only, lower half not compatible/saves 4.6g total)
Driveline:
LA211B - Plastic drive cups for center drive shafts coming out of front & rear gear boxes (requires drilling two holes for set screws to secure LA379)
TFW001 - Aluminum blade style outdrives (for ball diff/requires TF013)
LA202 - Aluminum pinion shafts (for ball diff)
TFW126 - VVC outdrives (for gear diff - front/rear/center)
TFW008 - VVC cross pins (for gear diff - front/rear/center)
Misc:
LAB06LW - LW Blade body
SK0402 - Ti screw set (Available at Lunsfordracing.com)
PTK-T-2111 - Ti screw set (cheaper, slightly less durable option)
LNS7765 - Ti ball studs
LNS2688 - Ti Turnbuckles
LNS36107 - Ti Turnbuckles (super duty)
W0201H - Hard anodized lower shock balls
1-N3024A-R - Aluminum M3x2.4 nuts (for shock standoffs)
1-N3033NA-R - Aluminum M3x3.3 locknuts
Print Wikipost
Old 04-22-2015, 11:13 PM
  #1426
K_King's Avatar
Trader Rating: 47 (100%+)
Old vs New
Way less milling on the new chassis.
K_King is offline
Old 04-23-2015, 07:38 AM
  #1427
Brian C.'s Avatar
Originally Posted by K_King
Old vs New
Isnt the new chassis supposed to have more flex?
Brian C. is offline
Old 04-23-2015, 07:45 AM
  #1428
K_King's Avatar
No it's going to have less.
K_King is offline
Old 04-23-2015, 08:12 AM
  #1429
Location: South Coast RC Ministry of Propaganda, Dorset, England
Old vs New
With the stock chassis it's a very flexible car, I can flex mine in my hands quite easily.
HOTSHOT III is offline
Old 04-23-2015, 08:28 AM
  #1430
Super Moderator
Kraig's Avatar
Trader Rating: 81 (100%+)
Old vs New
If the top is the old and the new is the bottom I am confused.
When looking at the old chassis pic, if the above statement is true, it looks like they took away the extra material where they had originally milled in the pockets on the old chassis. So now, the only thing left over from the old chassis on the new chassis is the middle spine. Which leads to my confusion, by taking these other raised edges will create less flex? I thought it would be the opposite.
I hope what I am saying makes sense to you.
Kraig is offline
Old 04-23-2015, 08:33 AM
  #1431
Brian C.'s Avatar
Ok thanks.
Brian C. is offline
Old 04-23-2015, 08:58 AM
  #1432
K_King's Avatar
Taking material away will create more flex. They basically didn't mill it out and added some more mounting holes in the middle to adjust the diff forward and back for additional weight bias tuning.
K_King is offline
Old 04-23-2015, 09:48 AM
  #1433
Stevomatik's Avatar
What's your guys take on the light weight body?... Too flimsy should I stick with the regular body?...
Stevomatik is offline
Old 04-23-2015, 09:53 AM
  #1434
K_King's Avatar
Technically? A lighter body should be better because it lowers the CG.
Realistically? If you wreck a lot it won't last as long. I run the 2W LW and am having no issues with durability. I'm going to send a 4W LW to my painter to get done.
Another deal is I use a practice body to keep my painted one lasting longer.
K_King is offline
Old 04-23-2015, 10:00 AM
  #1435
Stevomatik's Avatar
I see thanks for the info. Think I'm gonna go for the LW cuz I don't wreck that much... (geez now I sound conceited)
Old 04-23-2015, 11:27 AM
  #1436
Super Moderator
Kraig's Avatar
Yeah, I hear what you are saying. I guess I will have to wait and see the chassis in person.
Kraig is offline
Old 04-24-2015, 08:15 AM
  #1437
Trader Rating: 166 (100%+)
lol... you don't crash huh? j/k.
jpcopeland1 is offline
Old 04-24-2015, 10:42 AM
  #1438
Stevomatik's Avatar
Ha!... Well at least I'll really try not to with this zx6 I have now... currently masking it up for a fresh paint job... Pumped, first drive is tomorrow
Old 04-24-2015, 12:28 PM
  #1439
ProfessorX's Avatar
Trader Rating: 18 (100%+)
How do I break in the ball diffs in this car !!!???????
ProfessorX is offline
Old 04-25-2015, 11:30 AM
  #1440
ProfessorX's Avatar
Bump for info
