TLR TEN-SCTE 2.0 Kit Thread
#3481
I am having extreme looseness in the rear of my truck, which means i need more rear traction. I was running the same setup as the dunford standard setup minus having stock pistons and 27.5 oils all around. What are some changes I can make?
I tried a longer rear camberlink by moving it inner lower on the rear, move the hubs forward so that one spacer was front and 3 behind. moved the battery back. moved the shocks in one on the tower in the rear. Nothing worked loose loose loose mainly on mid to exit of the turns. And i have a buddy who has had the same issues and couldnt figure it out either. Would it be smart to add some weight to the rear? So far on it outdoor track the car wont be driveable. On indoor tacky clay track the car is awesome. And i had the right tires on as the number 1 and 2 drivers were using the same thing.
#3482
I ran my 2.0 at the track yesterday and I don't have as much steering to the left as I do to the right?
#3483
Raced my first race ever last week. The 2.0 did awesome. Placed 6/8 4/8 5/8. We ran the main all together. Defiantly hooked on racing now! Had a few glitching issues the first heat (also a bit nervous for my first race haha) but fixed those for heat #2 and the main. Can't wait to get back to it this week!
#3484
#3487
#3488
The team mostly runs there's all of the way tight. For most, I suggest tightening it all the way and then backing it off 1/2-3/4 of a turn. Always be sure to put thread lock on it.
#3491
Just wondering if anyone has some sugggetions on what gearing I should run on a losi scte for general bashing. Using as turnigy nanotech 2s 6600mAh 65c. I have a 3800kv 401 tenshock motor with a hobbywing sc8 esc. Also if anyone has any esc settings suggestions. Would like to use 3s as well not looking for massive speed but would like things to run quicker than the rtr setup and cooler. Thanks
