TLR TEN-SCTE 2.0 Kit Thread
#3181
#3182
Obviously we know this is the scte 2.0 thread as I stated in my last post and that it was getting out of hand but...I really hope you're being sarcastic about this post you made, if not..."You SIR are a HYPOCRITE"
#3183
#3184
I like all the talk about electronics, theories, favorites and such. I like it because when people are harping on things like that in the SCTE forum (instead of reporting faults with the truck itself), it lets you know it's a pretty darn good truck.
That said, anyone with any new mods or findings on the truck? Any SCTE pictures to share?
#3185
I dont think any mods are needed. The only thing i want to try is getting rid of the thumbscrews and plactic hold down and adding the tekno long strap. I ve experiment with softer front spring and 1 spring stiffer in the rear, and shorter ancherman.....which all gave me more steering. Tried 5-7-3 diffs as opposed to 553 and made the truck a bit more stable.
#3186
Ya that is for my current indoor track which tight dirt clay mix usually moist surface, So usually get a decent amount of traction. I wanted my truck to be slightly more loose/have more steering so i tried it and liked it. Might be a whole different story come outdoors. Also, running stock 3,4 pistons and close to 27.5 shock oils all around(whatever came with the kit). Also, i am running more -2.5 rear toe instead of 3.0 and running 2.0 rear sway bar i believe its the middle sized sway bar. Everything else i have setup the same as the first page setup. I am not expert at tuning/driving just saying what i tried and liked. Have not tried different camberlink locations yet. I tried the phend/fischer setup at my local track and it was terrible, tight off power and loose on power.
#3187
I've only had a chance to put front diff and case together so far. My issue is I have a tight spot where the diff gear and pinion gear meet? It will be really smooth then in one spot in rotation it's tight? I have both bearings in cases the diff it's self is very smooth I noticed that it was a tight fit when installing the diff into the diff case's but I'm at a loss as to why it's doing that.
#3190
I have also used 7 10 5 in my 1.0 and liked it. I use that when the track has less tight turns. When I run that combo people slowly catch up to me in the turns then I leave them in the dust when I open it up. Has long as I don't get behind that combo works very well. People will come up to you and ask what motor you run and you tell them the same one they have. The look on there face is priceless!
#3191
So I went to an open practice last night to try some things. I ended up running lap times comparable to the guy who TQed last Tuesday. I read some setup guides online and wanted to try some different shock piston oil combos with the stock springs. The track is indoor clay/dirt mix and it was damp. What worked the best was the #4 pistons in front and #5 in the rear with 35wt front and rear.
My diffs are 5 - 10 - 3. I want to try 7 in the front. Does anyone have any experience with putting 7 in the front? What will it do compared to what I have now? Also the 10 in the center, to much? What will I see and feel if I go to 7?
Thanks guys. I'm loving this truck.
#3192
