Mid motor 2wd SC truck opinion? >
Old 10-15-2012, 10:44 AM
Default Mid motor 2wd SC truck opinion?
I'm building a 2wd SC out of a firestorm 10t nitro chassis. The mid plate will be longer to make up the wheelbase difference and the motor will be located in front of the rear diff. I can use Blitz front bumpers and ill have to make a mount to use the spare slash 4x4 rear bumper I already have.
Has anyone ever tried to run that config? It probably won't have enough weight in the rear, but I can add some after the diff if needed. The battery will be lengthwise right in front of the motor, so the heavy stuff will be all toward the rear.
frankenstang is offline
Old 10-15-2012, 10:51 AM
Woulvesbaine's Avatar
Check with the Xfactory team. They make a conversion for the SC10 that's a real work of art - carbon fiber, balanced and tested.
Woulvesbaine is offline
Old 10-15-2012, 12:21 PM
Trader Rating: 21 (100%+)
There are a few other conversion threads on here for the Firestorm.
MX304 is offline
Old 10-15-2012, 04:33 PM
Other than the thread from the guy that HATED the car, any other results? How well do the SC10 conversions run?
Old 10-15-2012, 06:48 PM
Thread on RCTech: http://www.rctech.net/forum/electric...-scx-60cf.html
X Factory web site, with a whole section on the mid-motor carbon fiber SCX - 60CF: www.XFactoryRC.com
FaceBook: XFactoryRC
We've done all the engineering work for you, it's the only CF SC truck on the market -- your friends will drool -- and it's ballistic fast.
YoungChazz is offline
Old 10-15-2012, 06:57 PM
This is my Slash-based mid-motor 2wd SCT. I run right at 57% rear weight, compared to ~61% when it was rear motor. I prefer mid-motor over rear-motor on any surface, really. I prefer the cornering attitude all the way from turn in through exit.
Dr_Isotope is offline
Old 10-15-2012, 08:52 PM
That slash is SICK!. Looks like we're on the right track. I was shooting for a 6 inch wide middle, might go to a 5 inch now. Also, the battey will be mounted further back on mine. I can adjust the mounting if needed. Lots of real estate in the middle.
My brother in law is ordering the 7075 alum sheet this week. We will cut the 1st one on his mill. He is a tool and die designer by trade and has access to a water jet. Just gonna cost me too much $$ to get that deal going. Unless I can convince a dozen people that this works.
I still need a 2nd set of tires and wheels. Everything else is on it's way. Getting all antsy now...
Old 10-16-2012, 07:44 AM
elecRC23's Avatar
what about the 22sct?
Edit, oops sirry, didnt read the first post
elecRC23 is offline
Old 10-16-2012, 03:33 PM
Tech Legend
Cain's Avatar
Trader Rating: 294 (100%+)
had a mid motor SCT based on the Academy GV2T platform. It would turn inside pretty much any rear motor SCT. Very quick as well. If I could have found a chassis cover I probably would have kept it. It ran an FRP chassis that allowed more flex than a carbon fiber one which on the loose stuff here was a big plus.
If you can get the rear to hook up, the mid motor cars are awesome.
Cain is offline
