Like Tree2Likes
Old 11-22-2014, 11:28 PM   #1051
dust1905's Avatar
Anybody have slipper issues with their durango? I've taken it apart a few times and swapped out with AE pads and it slips way too much never fully engages. I can lock down the spring and still slips like crazy?
Thanks!
dust1905 is offline   Reply With Quote
Old 11-23-2014, 12:04 AM   #1052
Thanks!
Hello dust1905,
Have a look at the dex210v2 manual, they put now two shims behind the first slipper plate, that brings the hole asambling a bit to the outside, and have a look at your layshaft spacer, too, the older one did worn a bit to easy!
There was a running change on them, the older one were silver, the newer one are olive green, like the aluminum hinge pin holders.
Greetings from Austria
Cat K2 / DEX410V3 / DEX410V5 / DEX210 / DEX210F / Cougar SVR /
YZ-10 '94/'95 WCS/
Spectrum DX3R
micholix is offline   Reply With Quote
Old 11-24-2014, 05:24 AM   #1053
Trader Rating: 57 (100%+)
Thanks!
That definitely doesn't sound right. Make sure the slipper plates are lined up right. Maybe of of the pieces is defective that's not allowing a proper fit.
shagino is offline   Reply With Quote
Old 11-28-2014, 07:30 AM   #1054
Jeepy2013's Avatar
Trader Rating: 79 (100%+)
As mentioned above, the V2 uses 2 small shims behind the first slipper plate. I've only had to shim one of my older cars though. The shaft where the adjustment is, is only threaded down so far, by putting a small spacer or some washers on before the locknut, it will allow it to be tightened more. Even with AE pads, I run a small spacer before the locknut and once mine was adjusted properly I haven't had to mess with it.
Jeepy2013 is offline   Reply With Quote
Old 11-28-2014, 07:38 PM   #1055
platgof's Avatar
I am getting my DEST210 off the shelf and back on the track again. I am running a Reedy 540 Sonic 8.5 and trying to figure out what pinion to use, does 23 sound right?
platgof is offline   Reply With Quote
Old 11-28-2014, 07:41 PM   #1056
Kremzeek's Avatar
The last time I rebuilt my DEST210 I did what it says in the V2 manual and put one on either side of the spring and two before the first slipper plate. Works great.
Kremzeek is offline   Reply With Quote
Old 12-02-2014, 03:52 PM   #1057
Kremzeek's Avatar
The DEST210R is back in stock at Tower Hobbies. Limited quanities though.
Edit: Price has increased to $290 too.
Old 12-02-2014, 05:10 PM   #1058
trick25's Avatar
Trader Rating: 26 (100%+)
they done that before....then a few days later it was back down to 140.
17.5 2wd-XB2 17 CE , 2wd mod truck-xt2
4wd SC-SCT410,13.5 4wd -D413
trick25 is offline   Reply With Quote
Old 12-08-2014, 10:13 AM   #1059
joeld2llio's Avatar
Tried the cush setup this past weekend and the truck felt really good.
http://www.petitrc.com/setup/durango...etup201212.pdf
About the only thing I changed was a higher ride height. I've notice most of the setups for DEST and DESC have really low ride heights compared to what I ran my AE trucks at.
Not a lot of setups out there for the DEST but this one definately feels much better than box setup.
B6 - B6D - B64D - T5M - DEX410v5
joeld2llio is offline   Reply With Quote
Old 12-08-2014, 12:42 PM   #1060
iDesign5's Avatar
I just grabbed a DEST210R on a hell of a steal. I was wondering if you have to have a Type B chassis to use Type B components. Maybe a dumb, obvious question but I'm pretty much a noob with Durango stuff.
iDesign5 is offline   Reply With Quote
Old 12-08-2014, 01:46 PM   #1061
Kremzeek's Avatar
It depends on the part. What are you trying to do?
Old 12-08-2014, 02:40 PM   #1062
ekt
ekt's Avatar
The type B parts will fit the original chassis. Some type B parts require additional parts though. For example, the type B motor guard requires the RR suspension mount.
Leo Lorenzen
Xray Australia - Proline Australia - GForce Australia - Fantom Australia - Hearns Hobbies
ekt is offline   Reply With Quote
Old 12-08-2014, 06:36 PM   #1063
iDesign5's Avatar
Just getting my ducks in a row and looking at spares. I asked the seller if he'd ever had it mid motor and his response was I didn't know it was mid capable so I'm guessing whatever parts you may need aren't with it.
Old 12-08-2014, 08:10 PM   #1064
ekt
ekt's Avatar
Is it the kit version or rtr? The RTR version will need a couple small parts to be able to run MM4 but MM3 is no issues as long as you get all the parts that came in the box.
Leo Lorenzen
Old 12-09-2014, 03:02 PM   #1065
Fast410's Avatar
Trader Rating: 41 (100%+)
Anyone running the dest in mid motor version ?
I put one together and run it in 4gear mm have good steering and side bite in and out of corners , but suffer forward bite ..
GRUDGE RACING $$ PROMOD KUSTOMZ real race car fabrication and custom painting -airbrushing CHICAGO WISEGUYS RACE CIRCUT-1/4 mile Door Slammers @ 200mph plus
Fast410 is offline   Reply With Quote
Team Durango DESC410R Thread KostaG Electric Off-Road 12301 Yesterday 07:22 PM
