RCshox products and services
#2326
I was finally able to try out the new TRIFEX piston kit from RCSHOX.COM Normally running on a very smooth carpet track, I never had a "need" for the car to get back to ride height immediately after landing a jump. Knowing that the track i was going to be headed to was very tight and with short,steep jumps and non forgiving landings, i through in a set of trifex pistons ( 1.3compression and 1.5 rebound) in the buggy. I started with associate 27.5 in the front and 22.5 in the rear. I didnt notice a huge difference in handeling right off the bat, but once racing started and i was attacking the jumps with more speed, and overshooting them more than i should, i saw that the car wasn't "at rest" as long, after flat landing. it was coming right back up and ready for the next turn/jump almost instantly. With a little more time, and testing, Im sure these will be the hot setup, especially on tracks that have stutter bumps and/or turns right after the landing of a jump. Another great product !!!! I also tried the new slipper eliminator and spur gear......ZUM ZUM !!! Not only did it wind up faster, but it lowered motor temps by almost a full 10* !!!!
#2328
I bought SCT410 "newGen" pistons in January... but didn't install them until today when getting ready for the outdoor tracks. Went online to read more about them and see that TriFex made them obsolete
MantisWorx: Looking at the newGen/white pistons... is the bottom 4-hole piston a bit smaller than the top 6-hole... so on rebound some oil gets to flow around the outside of the piston? The two pistons look the same diameter: so I'm trying to get my brain around how they work. (e.g. how the top 6-hole helps rebound if the oil has to go through the 4-hole first?)
Thanks!
Thanks!
#2330
Thanks!
Thanks!
http://www.rctech.net/forum/electric...-services.html
post #2
The pullies are sold directly via Disount RC, they buy in bulk for that right. contact Phil direct and he will order more.
#2331
(deleted - misunderstood post #2)
#2333
Hey Marcus..!
New Schuie Tri-Fex are sweet..! These are by far the easiest to install. Really helps make the car feel consistent and confident... Ended up white base/black insert 350cst in front and white base/white insert 300cst in the rear ...
..apologies on that, we are expecting more in very soon..
..p
..p
#2336
TriFex installation links
screw on shaft 1/8 scale, Serpent SRX, HB D413
https://www.facebook.com/permalink.p...8¬if_t=like
E clip style
TLR 22 style
E clip style
TLR 22 style
#2338
Suspended
Has anyone tried the rc shoxs Pistons in the UK? Also the slipper pads with a k1 and kf?
I would be happy to test them for you and give feed back ?
Also promote on oople
#2340
Suspended
