E-Truggy  The next big class!!! >
Old 10-07-2011, 06:31 AM
  #61
kghills's Avatar
Trader Rating: 40 (100%+)
Decided that a hard case would be a better way to go when using a Lipo.
Keith
kghills is offline
Old 10-07-2011, 07:09 AM
  #62
BashemSmashem's Avatar
Trader Rating: 42 (100%+)
OUCH ! That must have been NASTY !
Yeah hard case packs are the way too go in RC cars , too much banging around for soft packs IMO . The GensAce 5000mAh 40c 4s batteries on hobbypartz.com are the real deal , ROAR approved , and a bargain at 59.00 IMO .
http://www.hobbypartz.com/98p-40c-50...-hardcase.html
BashemSmashem is offline
Old 10-07-2011, 07:27 AM
  #63
tc5 man's Avatar
Keith
Yea true even though i never had issues with soft cased lipos at all .
Sure it can still happen a guy i race with runs soft cased lipos also on his truggy .
I strap my pretty tight with the foam pads around the tray of course.
tc5 man is offline
Old 10-07-2011, 07:39 AM
  #64
IROC-AR15's Avatar
Trader Rating: 29 (94%+)
Questions??
Originally Posted by flysullivan
Hobbyking.com Turnigy 4s for about $40!!! I have used them all season with no problems. I also have protek and maxamps and can't tell the difference.
Gearing should be ok but you want to find the gear that just barely tops out on speed by the end of your longest staight. Start there but you may have to drop a tooth or two on the pinion. Time yourself and drive like you are racing for about 6 minutes ands check temps. If you are over 120 degrees you might be geared to tall. Keep your eye on it. I wouldn't go with 5s or 6s unless you are just a basher not racer. Most tracks are 4s max and it's all the power you need and then a lot more. Anything more is just hard to control no matter who you are. Remember also that more cells means more voltage and power, not runtime. More runtime is achieved my lower kv motors and/or higher capacity (mah)
Thanks, I really don't plan on racing using more than 4s just bashing with 5-6s pack. The site you gave me has good deals on 4s packs but I really didn't see any on 6s that fits my needs/wants.
Below are the packs I'm looking at all 5000mah with 30c or better. As long as I can get 15minutes out of a pack I'm happy!
1. http://www.hobbyking.com/hobbyking/store/%5F%5F14985%5F%5FTurnigy%5F5000mAh%5F4S%5F40C%5FLi po%5FPack%5FUSA%5FWarehouse%5F.html
2. http://www.hobbypartz.com/gensace4s40c.html
3. http://www.hobbypartz.com/77p-sl5000-5s1p-30c-5555.html
4. http://www.hobbypartz.com/77p-sl5000-4s1p-40c-4444.html
How do you feel about those packs? Will they do the trick and give me 15-20 minutes of run time...? My combo is Tekin RX8/2250KV
IROC-AR15 is offline
Old 10-07-2011, 07:40 AM
  #65
IROC-AR15's Avatar
Aw man sorry to see hear that...What happened?
Old 10-07-2011, 07:43 AM
  #66
tc5 man's Avatar
sorry i meant the guy i race with has never had issues with soft case lipos ethier.
But it can happen still just by looking at the pic.
tc5 man is offline
Old 10-07-2011, 03:18 PM
  #67
Trader Rating: 31 (100%+)
I mean 4s is really better for bashing too imo. You go higher voltage and you are really not putting the power down and you are tearing the tires off rims. It's overkill. The castle 2200kv on 4s will rip tires off. Plus it is best to go hard case. If you wreck into something bashing and your battery gets punctured you are going to have a bbq. My nickels worth of free advice. I say go with that gen ace. A couple of guys at my track use them with good results.
flysullivan is offline
Old 10-07-2011, 03:33 PM
  #68
Got 2 Gen Ace 40c 5k 2S1P hard case packs a few days ago. They seem great so far!
johnnychimpo is offline
Old 10-07-2011, 04:05 PM
  #69
joel804's Avatar
Trader Rating: 58 (100%+)
The gens ace batts are really good.One mine started to come apart at the seem nothing duct tape cant fix. Ive been running them since Feb. and for the dollar you cant beat them. STAW AWAY FROM HOBBY KING the gens ace are the same price
joel804 is offline
Old 10-07-2011, 04:09 PM
  #70
joel804's Avatar
Originally Posted by Mr.juarez
waiting on new lipos, charger, and a bce electric chassis for the 8t 2.0
you guys with the 8t how many are using the stock losi 45tooth plastic spur? i never used off the get go i went with a lightweight 48, but i did have to slightly shim the center diff up a bit. now that im going to use the 45 tooth i dont have to shim it, but then i need to step down the pinion size and the motor wont go any further in past a 14 pinion. no real heat changes or anything with the 45? i was always geared at 15-48
I use the 45 tooth spurr and run 16 pin or on really hot days 15. I have never had a stock plastic losi spurr strip out and I raced it almost every weekend since the begining of febuary
joel804 is offline
Old 10-07-2011, 04:34 PM
  #71
IROC-AR15's Avatar
Yes, I plan on grabbing two 4s for my race ventures and maybe one 5s and one 6s for bashing and definitely the Gen Ace hard case for racing!
Start off with the Gen Hard and Turnigy 4s packs! I don't plan on jumping head first and get the 5&6s off the bat
Old 10-08-2011, 12:54 AM
  #72
Trader Rating: 104 (100%+)
I ran a couple of soft packs through mine both etruggy and 1/10th scale no problems at all. Talking about etruggies, I got a rc8te ce converted to electric if anyone is interested ran probably 5 days outside. have a tekin and 2000 motor set up if anyone is interested pm me.
Ostach24 is offline
Old 10-08-2011, 02:48 PM
  #73
IROC-AR15's Avatar
Is it the Truggy motor? PM me Price, Stormerhobbies has my 2250kv on back order.
Old 10-08-2011, 06:23 PM
  #74
IROC-AR15's Avatar
Default Posting this
Seen this in the "Official Truggy Thread" thought it would fit perfect here...hopefully we can get enough on this to make it a sticky!
We can use this thread for assisting those trying to dial in their E-Truggy. Here's a blank template you can copy n' paste this with your info in it!
TRUGGY :
STEERING SERVO :
MOTOR :
ESC :
RADIO :
PINION :
SPUR :
WHEELS :
Tires:
DIFFS F/C/R :
SHOCKS F/R :
DROOP F/R :
RIDE HEIGHT :
CAMBER F/R :
Old 10-08-2011, 07:27 PM
  #75
Trader Rating: 20 (100%+)
buliding a 8t 2.0 it is going to have to run 20 min. I have rx8 so which tekn motor and size MAH battery should I get.
xxxtruck is offline
