rustler conversion help!
i made my rustler to a slash by makeing a replica of the strc kit. it came out great but my only problem is that my steering went down alot,it only turns like half of what it used to. any ideas why?
Be sure you have the rustler arm from the bellcrank to the servo saver. (shorter I think) mine is 46.1mm to center of each eye
I also have proline kit on mine and dremmeled the front of the arms on the bottom side for max turning with the "0" offset protrac wheels. The wheels hit the arms before full turn.
bellcrank is the same soooo something else changed if you had good steering before?
i will try and get pics up asap
i converted a rustler into a backslash awhile back, did you upgrade your servo saver? i believe that i used this one http://www3.towerhobbies.com/cgi-bin...?&I=LXS361&P=7
