Jammin CRT.5 Brushless
#407
I just installed the PBS system on my Jammin. It is very durable so far and easy to install. I would say that I like it better than the stock set-up. Worth the $50. You'll spend more than that on spare parts every time you break something.
#408
Sounds like a good investment. Can you post some pix?
What exactly is the "PBS System?". Got a link or something?
#409
once i calibrated the controller...the truck is fast like it should be on 3S. i also switched it to full sensored mode on my mamba max pro ESC instead of SmartSense. gives it some real kick...now i need a wheelie bar lol. anyway i posted a video of it before i calibrated the controller. 14/46 gearing. if ti wasnt raining i would post a video of it now...its fast as fuuk
#410
#411
Some people just replace the upper arm with turnbuckle.
#413
#414
I ran a traxxas Slash camber link for a while with all the aluminum upgrades and it was just not durable enough for the SCRT10. Racing with a ballistic 550 4.5 motor and large 2s battery I would always break arms or something else. So far the PBS system has been better when hitting the big 8th scale jumps and landing hard. Since I am racing the SCRT10 I felt it was worth it. I put more money into the aluminum parts already. I will post if anything breaks.
Has anyone looked into converting their Jammin SCRT10 or CRT.5 to an 8th scale buggy? I have worked out the details now. For a CRT.5 you would only need the following:
1) Traxxas 2WD Slash front 17mm adapters (est. width 301mm!)
2) 8th Scale wheels and tires
3) SCRT10 Chassis with chassis braces and center dogbones
4) Jammin X1CRT mudguards and fasteners
4) Jammin X1 or X2 body
5) 8th scale wing
6) CRT.5 steering bellcrank plastic tree. Buggy body mounts needed
From the Jammin SCRT10 it is much easier. All that is needed is:
3) Jammin X1 or X2 body
4) 8th scale wing
5) CRT.5 steering bellcrank and Wing plastic trees. Need Buggy body mounts and rear wing/front bumper.
5) 8th scale wing
4) 8th scale wing
#415
I'm not going to convert mine but that's awesome you put the parts list. I do want the 17mm wheel adapters.
#417
#419
#420
From what little info I found someone used 50mm turnbuckles.
