TLR 22 Racing Buggy Thread
#3196
The shocks will less likely bottom out after jumps and bumps because the bladder flexes, more of a solid feel I guess.
#3197
They are building the shocks more like an AE shock...with a bit of air in them. You cut the bladder out and basically leave the rest as a gasket or top o ring. The hole in the shock cap gets sealed when you tighten the cap onto the body so leakage will not be an issue.
#3198
#3199
So you leave a bit of air in the shock ? Doesnt the oil foam up? Im just getting back into the game but we used to build them with no air and a little rebound. The ancient AE shocks circa 1990 had just a little o ring between the cap and body and it was nearly impossible to get all the air out....the bladders fixed that issue.
#3200
The AE shocks were designed to have a bit of air in them. In off-road this will provide a smoother shock and should create a more stable / predictable handling car. With the bladder it will cause it to feel a bit more bouncy as their is no air in the oil...the air is above the bladder.
#3204
OK, these are gettin close to being in our hands here.
Any advise before building would be nice.
Tips that may deviate from the kit setup for us heading to the So Cal clay tracks.
I'm seeing the shock bladder thing, any other team guy opinions on this?
Frank, Mike T., Dustin, Matt? (droppin the names of the big dogs )
Shock oil wt, springs, shock mount positions, camberlinks, ride height etc...?
OR will the kit setup still be a safe neutral place to start as has always been the case with Losi kits.
