Good cordless screwdriver
#16
This one has been great for me. I like the quick change and the light. It is only 4 volts but has clutch and the price is right. I always save the last bit of tightening for a hand driver
http://www.homedepot.com/Ryobi/h_d1/...atalogId=10053
+1. Been using the Tek4 version of this one for over a year and loving it.
#17
http://www.homedepot.com/h_d1/N-5yc1...atalogId=10053
#18
#20
#21
this is the best one imo just need to get one now lol
#22
There are several good choices. I've had the little Ryobi for a few years, as do plenty of buds, works fine.
The clutch can easily go lower than needed for any screw I have seen or would use it for to begin with. I usually use #3 to 4, on typical 1/10 scale stuff.
The speed is slow enough to be controllable, but it would be cool to have variable speed I think, about the only shortcoming I can think of. But I could also see variable speed being more of a hassle than worth, don't know.
For me any unit with a nickel based battery is unacceptable, no matter how good the charger or the unit itself is.
#23
I use the power screwdriver by Channel Lock. I got it at Costco for $15. It's 4v Lithium Ion with a clutch and a light. It also has a battery "checker" on the drill, push the button and l.e.d. lights light up to show you where your battery status. Also it transforms from a regular drill profile to a straight drill...totally worth $15!!
#24
#26
EDS are nice
#27
If you are really budget minded try this one. It works well.
http://www.harborfreight.com/48-volt...kit-95065.html
#29
Believe it or not, and most won't, but the Integy TiN coated drivers are awesome, and for the $25 they cannot be beat.. I've assembled one kit, and maintained 2 kits for almost 9 months, and the 3.0mm shows very little wear, and it is the most used tip. the coating is the key..
#30
I use this one.. It also comes with a nice case
http://www.amazon.com/Black-Decker-V...8411268&sr=1-2
