Rc8 Spur Gear on a vorza?
Will a Rc8 46t lightweight spur gear fit on a vorza? Is there a company besides hpi that makes a 44 or 46t (lw) spur that will fit a vorza?
Did you try that Zmxb spur i gave you? You said it looked fatter but as long as the screw holes are in the same place it shouldnt matter.
no worky
It makes my entire center diff setup too wide.
Did you put enough plutonium in the flux capacitor?
The Kyosho plastic one fits. I'm using a 46t. I have my center diff raised about 2.5mm as well, so no clearance issues on the chassis. I've read that the RC8 spur will also fit.
ben
ben
46t
http://www.amainhobbies.com/product_...-46T-Spur-Gear
44t
http://www.amainhobbies.com/product_...r-Gear-Plastic
Just know that you have to sand the leading edge on the spur for it to slip onto the diff housing. It is a very tight fit, but that is good because it helps prevent leaking.
I've gotten great wear from my 46t spur. Bought two of them, and other is still in the package.
ben
44t
ben
46t
44t
ben
44t
ben
