Which Lipo will last 12 min. main?
12 min with a SC10? lol how heavy is it and what motor are you running?
with a 4000 mah I run for at least 20 minutes and with my 5200 I do easily 30 minutes
do you run beadlocks?
Any of the current 30 to 40c 5000mAH or better lipo's will give you some run time to spare... 4000's depending on your setup may cut it a little close. In a stock class limited to 13.5 or 17.5 the 4k is more than enough, but I'd still recommend going w/ the 5k lipo's with high C ratings as it will last you forever and keep a little better voltage curve, expecially near the end of the 12minutes.
