PSI Racing Mid Motor Conversion Products
#1066
Location: anywhere I can race 2wd dirt,and 1/12 onroad in MI.
Trader Rating: 42 (100%+)
#1067
Got my LMX-T yesterday.
Now to build it!
Avner.
Now to build it!
Avner.
#1070
#1071
I would love building my LMX-T with the gear diff 4 gear trans, should I wait for it or is it still a long way off?
Avner.
#1072
#1073
#1074
Here are pics inside and out. The set is a 3 peice set.a .125 G-10 fr4 spacer gets sandwiched between the 2 halves.Included in the set will be the 2 delrin halves,G-10 spacer, idler shaft,idler bearings,idler gear, and top shaft spacers to adjust the slipper depth(R slipper plate on the shaft).
#1075
#1076
#1077
man those things look good in black, can't wait to get mine. On a side note, a guy in the UK said the ball diff version needed some modding to fit in the CR2, I asked im to post pics of the mods needed but haven't seen any. When will the gear diff one be ready? what advantages does it offer over the ball diff on the track?
#1078
As for the availability of gear diff cases, I am going to be listing a Pre-order of the first batch of 10 case sets Tomorrow.The ship date will be listed as being on (or before) 11-6-10.I got a TON of e-mails wanting these cases so For the first batch I will need to do the pre-order to also keep on top of everything else.
Also for those that plan to order the gear diff tranns cases for an atomic carbon CR2 , contact me and let me know and I will make sure you get the version you need for the CR2.
#1079
